Heli Tape Instructi...
[Closed] Heli Tape Instructions & Tips?
[#4233786]
Getting a new bike delivered today!!
I have some heli tape from Biketart. Does anyone have any really good tips/instructions/tutorials?
I was thinking of using the wet method, does it work well!?
Posted : 07/08/2012 10:10 am
Hair dryer, heat the frame and the tape before applying
Posted : 07/08/2012 10:19 am
Always put mine on dry. Clean surface with IPA then heat frame and tape with the wife's hair dryer. Use curved corners when you cut it, not square ones.
Posted : 07/08/2012 10:20 am
What onzadog said.
I did my top tube neatly, kinda bodged the downtube, then got annoyed and just did the chain/seastays with 1" strips wrapped like abr tape.
Posted : 07/08/2012 10:33 am
As onzadog, but I do apply wet, I find I get less bubbles - more time to adjust position, could be I'm just ham-fisted though... 😐
Posted : 07/08/2012 10:38 am
I've got loads of IPA, a microfibre cloth, hairdryer and some A3 paper to make some templates. The one thing I don't have is patience!
Heat the frame? Even a carbon one!? 😯
Posted : 07/08/2012 10:40 am
IPA, put on wet, don't stretch it too much or stretch it over concave curves. Use hot water to soften the tape, I certainly wouldn't hairdryer my own frame.
Posted : 07/08/2012 10:48 am
Wet method ?
Que?
Posted : 07/08/2012 10:49 am
scruff - Member
Wet method ?
Que?
Posted 15 minutes ago # Report-Post
Posted : 07/08/2012 11:08 am
Utubes blocked.
Posted : 07/08/2012 11:10 am
Peel the backing off, then you dunk the tape in water (with a little fairy liquid) before applyin.
Apply tape and after squeegee the water out with a credit card. Makes applying easier as its slips around on the bike.
Of course you have to leave it to dry for a while.
Posted : 07/08/2012 11:14 am
Wet application (I have done it) is absolutely **** for anything apart from top tube, downtube and maybe fork stanchions. Everything else apply it dry and just be f'ing careful.
Posted : 07/08/2012 11:21 am
Well I tried the dry method, made up some templates, got the hair dryer out, heated the tape.. Stuck it on...
I'm now giving up and not using any heli tape! I struggled with just a fork leg! The power bulges created loads of creases and bubbles. I might give the wet method a go this evening, but I can't see it being any better.
Also the frame has a matt finish, so I can't imagine it looking very good with the shiny heli tape over some bits.. Here's the bike I'm trying to tape.
Does anyone know of any LBS's that offer a heli taping service!? 😆
Posted : 08/08/2012 8:41 am
