I've run an E13 DRS in the past and now run a Heim2 system, I'm finding it pretty noisy compared to a DRS. Anyone else find them noisy ? how have you solved the noise if you have ?
Cheers.
I'm also in the same boat, I've tried looping a strip of inner tube round the smaller diameter roller. Last time i wedged it in which lasted about a rides so not great longevity, but did quieten it down quite a bit.
Next up is to super glue the inner tube to the roller, see how long that lasts.
I was also wondering whether you could cut a section of road tube so it was a seamless ring?
Anyone else got any tips?
bugger.... I remember the DRS had two rollers, a soft and firm one. The soft was quite, but wore away. The heim must be a higher shore than the DRS.. but why go backwards.
