Heckler rear disc m...
[Closed] Heckler rear disc mount issue
[#5027980]
I'm trying to fit my brakes on a 2012 Santa Cruz heckler but the bolts do not fit through the frame bolt holes. The washer (non removable stops them fitting through the frame.
Is this normal? Is there a simple way to remove the washers, without sawing,as I'm guessing they are part of the fit.
Thanks everyone
Posted : 03/04/2013 9:26 pm
Buy some new bolts without washers? I hacksawed mine off last week building my Heckler - fairly straightforward with a vice.
Posted : 03/04/2013 9:35 pm
No vice mate. Yeah I will go get some new bolts tomorrow.
Oh well nearly finished as well.
Posted : 03/04/2013 9:38 pm
I found this to be the case as well, fortunately the washers on the bolts hope supplied with the mount were removable.
Posted : 03/04/2013 9:50 pm
Try holding the washer with a pair of molegrips, and twisting the bolt out?
Posted : 04/04/2013 12:28 pm
I tried that mate it is smaller than the thread so doesn't shift.
Oh well I'm off out to pick some bolts up now.
Slightly longer but I'm sure they will be fine.
Posted : 04/04/2013 1:10 pm
If they are too long, you can always hacksaw them in a vice ...... Oh, hang on, we've already been here!!
You don't want them too long, or they will stick through the adapter and foul the rotor. This sounds like the perfect excuse to buy a vice!!
Posted : 04/04/2013 1:12 pm
Normal, Shirley you have a big pot of old random bolts just for this porpoise ?
Posted : 04/04/2013 1:16 pm
Apparently in my big pot of bolts I don't have a single brake one without a washer that can be removed!
I can't believe it either!
Posted : 04/04/2013 1:22 pm
Well the shimano are m6x18.7 and the halfords are m6x20.0
Will this cause issues?
Posted : 04/04/2013 1:23 pm
I doubt 1.3mm is critical. What is the clearance when you put the adapter in the right place, between it and the rotor?Just hope the heads are the same size to fit into those cups on the Heckler!!
Posted : 04/04/2013 2:10 pm
I've just got the bolts so I'm going to try now. To be honest the difference is minimal so I can't see it fouling. Heads are smaller so fit just right.
What a ball ache for something so simple.
Posted : 04/04/2013 2:35 pm
Fitted and doesn't foul whoop
Posted : 04/04/2013 3:41 pm
