Heckler Main Pivot ...
[Closed] Heckler Main Pivot Bearing Replacement
[#4240736]
For latest style swing arm (ie: screw in pivot, no pinch bolts in swing arm). Same arrangement on Butcher.
The shop fitted the (angular contact I think) bearings the wrong way around (blue seal out) and one has collapsed. Want to fit replacements myself, but SC website suggests 2 tools are needed, cost over £50.
Anyone successfully replaced the bearings with homemade drifts/sockets?
PL
Posted : 09/08/2012 8:32 am
My collapsed ones were drifted out using "normal" drifts - took a while though as they were well gone (also proper shop mechanic as my tools were all shipped off to Oz by then)
Posted : 09/08/2012 8:35 am
Ooh they've put the price of the drift up.
Where are you (I'm in Dorset)? If you're reasonably close can borrow my tools. Easy job with the right tools.
Can't comment on doing it with homemade drifts.
Posted : 09/08/2012 8:55 am
Freester - I'm in Lancs, but thanks for the offer.
There are two tools, one for removing and one for fitting - do you think both are essential?
Posted : 09/08/2012 8:59 am
 nbt
Drifting out - hammer and screwdriver
"drifting" in, use a press - nut and bolt with a suitably sized washer to provide pressure on the outer race without interfering with the frame
Posted : 09/08/2012 9:24 am
I decided to be cautious and bought the tools, figured it would still be cost effective compared to paying a shop and safer. The frames aren't cheap after all.
Posted : 09/08/2012 1:17 pm
The exact conclusion I've come to.
One bearing is falling apart as it was put in the wrong way around. I'm guessing the SC tool pushes on the inner race, so in that case am I just going to end up try to get the otter race out with a screw driver and hammer?
Posted : 09/08/2012 1:46 pm
 nbt
Can be tricky to do that, I had to throw away a hope freehub when some cheap ebay bearings collapsed. You could try to find a smaller version of these
http://www.ebay.co.uk/itm/3-PCE-HUB-BEARING-PULLER-INTERNAL-EXTERNAL-CAR-VAN-GEAR-PULLEY-3-4-6-SET-/160807843176?pt=UK_Hand_Tools_Equipment&hash=item2570e4f568#ht_3125wt_1172
search for "bearing puller".
On another note, is a "tool swap" thread a good idea?
Posted : 09/08/2012 2:24 pm
I like the idea of a tool swap thread - very useful and resourceful.
I just changed my bearings on Heckler 6.0, but if they sit in the same place, then its just a case of tapping around with a screwdriver to get them out, and I used a suitably large socket + hammer to get them back in (tried rubber mallet and then hammer/wood/socket but both methods didnt transfer enough force, hammer-socket worked in a couple of blows without damage to socket).
I didnt realise the bearings had a way round! Fortunately I put them in blue inwards.
Posted : 09/08/2012 2:56 pm
What about free Santa cruz bearings warranty? I take it you're not the original owner?.
Posted : 09/08/2012 4:26 pm
 scud
Superstar now do some cheap bearing fitting tools
http://superstar.tibolts.co.uk/product_info.php?cPath=36&products_id=529
Posted : 09/08/2012 5:00 pm
[url= http://superstar.tibolts.co.uk/product_info.php?cPath=36&products_id=529 ]from superstar[/url]
[url=
puller[/url]
+1 Scud
Got one of these from Superstar too, easy or what and no damage. Took me only a few minutes to remove all 8 from my trek remedy
Posted : 13/08/2012 12:45 pm
I have the official tools from stif not needed anymore yours for £20 posted
Posted : 13/08/2012 1:03 pm
As for the question about removing the bearings with the Santa Cruz tool. It's simple but clever. The funny end bit fits in through outside of the bearing, the drift pushes through from the other side and expands the funny end bit which grips the bearing from both sides. The same process works for both bearings.
Posted : 14/08/2012 12:02 pm
