Heckler Forks - any...
[Closed] Heckler Forks - any suggestions?
[#2206985]
I'm just waiitng for my frame to arrive early next week and now need to find some forks, ideally 140mm /QR15.
Any recommendations?
Posted : 20/11/2010 4:32 pm
Most people seem to rate Fox 36 Vans as the best Heckler fork
Posted : 20/11/2010 5:02 pm
36 talas
Posted : 20/11/2010 5:26 pm
Or at least something with a 20mm thru axle. If you are going to ride a burly frame, it's a bit pointless putting a noodly fork on it.
Posted : 20/11/2010 5:35 pm
Fox 36s... 🙂
Posted : 20/11/2010 5:37 pm
I had a Talas 36 on mine , 130mm was great for climbing then flick the lever for 160 for the rest, never used the 100mm..
Posted : 21/11/2010 12:18 am
What do you actually intend to use it for? Hecklers can do all sorts. If it was mine I'd have maxle'd blackbox Revelations in it most likely, ridiculously brilliant forks.
Posted : 21/11/2010 12:24 am
Pikes (Push'd) here, work very well
Posted : 21/11/2010 12:39 am
I use Pikes on mine.
It's the older frame that theoretically doesn't take 160mm forks.
Posted : 21/11/2010 12:53 am
I'll be using Lyriks
Posted : 21/11/2010 2:21 am
Lyrik U-Turn for me. Set at 130ish for trail riding and then wind it up to 160mm for fun on the steep stuff.
Posted : 21/11/2010 5:45 am
