Heavier blokes ridi...
[Closed] Heavier blokes riding orange 5's........help
 ton
[#2147308]
just wondering if there are any big blokes on here using orange fives.
some shock/frame ratio's do not suit heavier riders..is the five one of these.
any info greatly appreciated..thanks
Posted : 01/11/2010 6:18 pm
Define heavy?
I know some fairly generously proportioned people riding Fives and a Patriot, and not had any problems that I know of.
450lb spring was changed for a 650lb.
Posted : 01/11/2010 6:23 pm
I'm 14 and a bit stone fully kitted so not uber heavy but i run a 700lb spring on my shock. No issues with the ride apart from the noise!
I'd say a coil shock or a custom valved air shock would be beneficial though as my rp23 blew through its travel way too easily.
Posted : 01/11/2010 6:35 pm
ton ridden my five while 125kgs plus 5kg of pack shock at 285 psi no issues at all. I am a lot faster up hill since I've got lighter mind!! 😆
Posted : 01/11/2010 6:45 pm
I had a Five, 09 model with a 20" frame.
I'm 6'2" and 14.4 stone.
Can't remember what pressure exactly I ran but found it worked best for me at 15% sag.
I really liked that bike.
Posted : 01/11/2010 6:53 pm
19 stone here and riding a new orange five. I have the 20inch version and ride on natural trails in the wyre forest and surrounding area. No issues at all with the shocks, front or back. I run the rear at 285psi and the front @ 125psi( iirc). Even loaded up with kit the rear shock performs well, I have no issues with bottoming out and there is plenty of travel left once I am aboard.
If you local to Bewdley more than welcome to have a blast on it
Posted : 01/11/2010 7:01 pm
15st here on a 2010 doing jumps drops etc. Running rear at 285 and a lyrik coil 160 fork. Would like a coil shock as reviews with coil shocks say they are excellent.
Posted : 01/11/2010 7:09 pm
Ton there is an Awesome 5 in the shop at Llandegla, if it is your size then get it!!
Posted : 01/11/2010 7:11 pm
17 stone here fully kitted out - very agressive rider. I run a 500lb spring on a ccdb on my 5. never had any problems . I think the 5 and alpine suit a more substantial rider as they have not been made to be ultra light - its very rare you hear of them snapping , and I have tried very hard!
Posted : 01/11/2010 7:28 pm
Over 100 kilos here (probably 110 suited and booted) at 275 psi with no problems
Posted : 01/11/2010 7:45 pm
 ton
so running one with a rp23 is a good option?
i run 275 psi in my rp23 on the ventana and 130 in the forks.
more i look at em more i want one.....
Posted : 01/11/2010 7:48 pm
I was impressed - but I'm only a lightweight!! 😆
[url= http://farm5.static.flickr.com/4126/5027553742_3ab02bbecd_z.jp g" target="_blank">http://farm5.static.flickr.com/4126/5027553742_3ab02bbecd_z.jp g"/> [/img][/url]
Posted : 01/11/2010 8:08 pm
 ton
dave........you bought one ❓
Posted : 01/11/2010 8:09 pm
No - had it for 3 days - if I had not already got the Hemlock I would have one though.
Posted : 01/11/2010 8:12 pm
 ton
you liked it then?
Posted : 01/11/2010 8:14 pm
 igm
I've ridden mine in Les Gets with my son on a LOCT - all up weight 20st.
No problems. Rode well, strong enough.
Didn't jump it - but we scared a few lads on the side of the 4X course when we did it.
Posted : 01/11/2010 8:19 pm
Get another Heckler Tony... You know you want to.. 🙂
Posted : 01/11/2010 8:21 pm
It needs the roughest trails, big rocks and a madman sat on it and it is wonderful 😆 - Damn thing nearly broke both my ankles when I cracked them off the swing arm a few times though- poor technique on my part I expect!!
I set it up quite soft at the rear and propped it up with the propedal to climb or do any road bits - it was good
Posted : 01/11/2010 8:22 pm
If a standard shock doesn't work very well would a high volume shock be better for a heavier rider maybe? Maybe a DHX Air?
Posted : 01/11/2010 8:31 pm
Posted : 01/11/2010 8:32 pm
Teetosugars - Member
That or the Five @ Llandegla!
 ton
houns, any idea what size mate.
Posted : 01/11/2010 8:34 pm
Must admit I'm sorely tempted too. Orange are having a demo day at llandegla on 13th november and I'm trying to resist giving one a go......
Posted : 01/11/2010 8:37 pm
hi ton you threw your leg over mine at the patley bridge ride.
I'm 18 stone and have no issues at all
Posted : 01/11/2010 9:07 pm
you finally joining the meltham/golcar Orange 5 club ? I hear trout finally surrended too !
Posted : 01/11/2010 10:05 pm
