Heating alloy frame...
[Closed] Heating alloy frame to help remove swingarm bearings
[#6306084]
So what's the favoured method of heating?
Blowtorch?
Wife's best hairdryer?
Posted : 30/06/2014 12:19 pm
Gentle blowtorch or vicious hairdryer action.
Posted : 30/06/2014 12:21 pm
Boiling water, at least there's no chance of damaging anything with it.
Posted : 30/06/2014 12:39 pm
Can't just pop them out with bolt and washers?
Posted : 30/06/2014 12:49 pm
Personally I wouldn't go anywhere near a heat-treated metal with more heat...
My preference is to remove stuck bearing races with a dremel (other rotary tools available). It's possible to grind out the race without damaging the frame.
Posted : 30/06/2014 1:29 pm
[quote=Conan257 ]Personally I wouldn't go anywhere near a heat-treated metal with more heat...
You don't go riding in the summer then?
Posted : 30/06/2014 1:30 pm
Few degrees of sunlight is bit different to a blow torch operating at 400 deg plus. Hair dryer wouldnt produce enough heat.
Come up with some sort of press/pull device from various bolts and sockets
Posted : 30/06/2014 1:34 pm
They aren't stuck, it's just that the swingarm acts as the bearing housing, so the outer race is not visible on one side. So you have to drive/force the bearing out on the inner race, which has the chances of going horribly wrong.
Was going to heat the frame a bit to make it slightly easier to get them out, whichever way I do it.
Intrigued as to how to pull with bolt/nut - would need some kind of interesting brace that allowed the bearing to come towards it....
Heath Robinson time I think.
Posted : 30/06/2014 1:39 pm
Or just a really big socket, maybe.
Posted : 30/06/2014 1:40 pm
Whats to go wrong - I imagine since your taking them out you have finished with them? your only going to damage the bearing as long as your Careful
Posted : 30/06/2014 1:47 pm
One of them is really knackered - ball bearing popping out knackered. just hope that there is enough 'bite' on the other balls to bring the outer race with them.
Posted : 30/06/2014 1:50 pm
[quote=joefm ]Few degrees of sunlight is bit different to a blow torch operating at 400 deg plus
As is boiling water.
Posted : 30/06/2014 1:51 pm
Schweet. Came out simple on the link, now for the swingarm.
Hmm. Supposed to be working...
Posted : 30/06/2014 2:38 pm
