Ok, I'm normally not one to give up on Google searching but this one got me. Need help folks!
Got a Lapierre XR929 frameset and need to stick a new headset in it. [url= http://www.lapierrebicycles.com/2014-bikes-mountain-cross-country-race-xr-929 ]Spec says[/url] stock headset is "CANE CREEK 40 Series 44/28.6 I 55/40 TAPERED" and I need to fit a fork with tapered steerer (Fox 29er CTD Evo).
To put it bluntly, what do I need here? Something along [url= http://www.tredz.co.uk/.FSA-SX-Pro-Internal-MTB-Headset_30768.htm ]these[/url] lines?
The 44/28.6 55/40 got me.
Steerer is fairly cut as well (2nd hand) so low profile is welcome. Oh, and if it can be red and less than £50 it'd be great. 🙂
Thanks!
[url= http://www.canecreek.com/headset-fit-finder ]Try here???[/url] I don't know where you've got to in your searching but this might help to get you started
You need to check the head tube to see how far the cups can be inserted too as that FSA one you linked to seems to have a deep inset.
The hope ones are around 9mm inset.
EDIT
[url= http://www.hopetech.com/wp-content/uploads/2014/03/HOPEHEADSETS2011Web.pdf ]Hope linky[/url]
A 44/28.6 top cup allows a 28.6 mm (~1.125") steerer to be used in a 44 mm ID head tube
A 55/40 lower cup allows a 40 mm (~1.5") steerer to be used in a 55 mm ID head tube so what you have are typical cups for a Lapierre/Scott 44-55 mm tapered headtube
Hope type 2 top cup and type G lower cup
HTH
Brilliant, thanks a lot.
As far as I can see, [url= http://www.bike-discount.de/en/buy/ritchey-superlogic-headset-press-fit-zs44-zs55-tapered-162357 ]This looks like the best deal at the moment[/url]. Quite a saving on UK prices, also helped by Euro rates. Just thought I'd pop it on here in case anyone else is looking.
