headset tolerances ...
[Closed] headset tolerances and compatibility
[#11756108]
New frame coming and headset required is
IS42/28.6 IS52/40
wiggle do one that will get mn going for tapered steerer but the measurement is
IS42/28.6 IS52/39.8
anyone know if that will work fine or will the 0.2 in the lower cup bearing ( i assume) cause issues?
thanks
Posted : 16/02/2021 10:36 am
That number refers to the lower steerer diameter. 40mm is the approximation of 1.5". 39.8 is also suitable.
Please can you link to headset, I need one the same.
Posted : 16/02/2021 10:43 am
certainly is
Posted : 16/02/2021 10:49 am
The lower bearing sits on a crown race and is self-centring - either size will work
Posted : 16/02/2021 11:33 am
