Headset replacement
[Closed] Headset replacement
[#7004171]
Ok, so my headset seems to be making various creaking noises, and despite putting it in a LBS for a full service they said that it doesn't need looking at, but I am sure that's wrong and they just couldn't be bothered.
I want to buy a replacement as I've no idea about them and could probably be doing with a spare anyway.
I have a Cube Ltd Pro, it is listed as a FSA No 10 semi integrated headset, but Google doesn't really provide much help as to where to buy a like for like replacement.
Anybody any ideas or can advise a worthwhile alternative replacement? Don't mind spending a bit extra if it's worth it.
Posted : 16/04/2015 11:48 pm
Is the headset creaking? Bikes are notoriously good at appearing to creak from one component, but it turns out to be something completely different. Did your LBS carry out a service? Maybe your LBS is correct?
The creak is quite likely to be from the handlebars/stem/steerer area
Posted : 17/04/2015 5:36 am
Fromy experience, a worn headset usually "grinds" rather than "creaks".
Try this.
http://www.chainreactioncycles.com/mobile/au/en/fsa-no-10-internal-headset/rp-prod108136
Posted : 17/04/2015 11:45 am
Thanks for the tips, I've ordered a replacement headset, also bearings, which I eventually found at ukbikestore, so will take the stem etc off over the weekend and have a deeper look and make sure it's all greased up and tight. And with a bit of luck will have a spare for the future.
Posted : 18/04/2015 12:52 am
