Headset Press
[Closed] Headset Press
[#5922617]
Got half of my hope he a set in the 1.1/5 end but can't get the top 1.1/8 bit in without it being majorly crooked.
My threaded bar and washers method has failed. So looking for a headset press but all the cheaper options only do 1.1/8 and would rather something that can do both.
Any recommendations that are not silly money?
Posted : 05/02/2014 3:06 pm
I just put them in with a soft hammer - I did make up a headset press but to be honest I prefer to just tap them in.
One of these, in fact [img] &Man=THO1&Size=460[/img]
Posted : 05/02/2014 3:10 pm
Whereabouts in the world are you?
You're welcome to borrow mine if you're anywhere near Shrewsbury?
Posted : 05/02/2014 3:11 pm
The one on planet x looked good when I had a look the other day. Has adapters for all the different sizes too.
Posted : 05/02/2014 3:12 pm
Unior one from http://www.eu-bikeshop.com/ has been recommended, and there's an unbranded one on there that looks to be basically identical.
Posted : 05/02/2014 3:15 pm
If you have a 1 1/8" tool, and happen to have ever bought a set of dumbells with free weights - one of the weight discs fits niceley on the bottom press to form an extra large press.
I must say I was rather pleased with myself when I discovered this 🙂
Posted : 05/02/2014 3:18 pm
kevin1911 - Member
Genius - I have a threaded rod, and a bunch of those. Ideal.
Posted : 05/02/2014 3:24 pm
I always find a sash clamp works a treat....tho' they can be a bit long!
Posted : 05/02/2014 3:25 pm
A bench vice works nicely too, if you've got one big enough and someone to help hold the frame.
I like the dumbell idea, though!
Posted : 05/02/2014 3:30 pm
In south Wales so bit far from Shrewsbury, thanks for the offer. Will take a look at those links thanks.
Posted : 05/02/2014 7:10 pm
Assuming the threaded bar of your press is a bit thinner than the hole;
Start with it as near the middle as you can.
As soon as it starts going crooked, STOP.
Loosen it off a bit and move it off centre towards the high side.
Pull it down just enough to get it level.
Carry on from the beginning.
Posted : 05/02/2014 7:34 pm
That worked on the bottom cup but the top just kept going in crooked.
Posted : 05/02/2014 7:48 pm
If the cup is stuck knock it out and start again. I have never failed with the big washer/threaded bar method. Try warming the headtube with a hot air gun and lightly grease the cups.
Posted : 05/02/2014 7:50 pm
If you've had a go and it's gone wrong, it's quite possible you've put a slight burr on the frame or cup.
Go round them both with a fine file and put a bit of a leading edge on them.
It doesn't need to be much at all, just enough to get it started square.
Posted : 05/02/2014 8:01 pm
Ebay for less than a tenner http://pages.ebay.com/link/?nav=item.view&id=111271972752
Posted : 05/02/2014 8:53 pm
2 words...
LBS + biscuits.
Okay so technically that's more than two words...
but its a darn sight cheaper than a tool you'll use once in a blue moon.
Posted : 07/02/2014 1:12 am
didnt need the tool in the end...
Didn't have a soft mallet/hammer so just picked up the frame and [i]persuaded[/i] the end sticking out to get level by using the frame as a hammer and smacking it into the (carpeted) floor 😆
Disclaimer: I do realised that this statement probably means nobody will ever take any mechanical advice or want to buy anything from me.
Posted : 07/02/2014 1:20 am
Rubber mallet here- actually do own a proper press but I almost never use it (last time I did, it exploded a headset cup)
Posted : 07/02/2014 1:21 am
