Headset Help
[Closed] Headset Help
[#11942548]
I'm putting a Surly Krampus fork on my 29er (EC44 Lower, ZS44 Upper)
The current bouncy fork is tapered 1.5-1 1/8, the new fork is straight 1 1/8" so if I want to keep the headset for easy swapping (I do) then I need a reducer.
Does the reducer brand have to match the headset brand, or do they all have the same dimensions?
Are all crown reducers created equal?
Posted : 30/06/2021 6:12 pm
They're all pretty much the same thing, so you should be ok.
Posted : 30/06/2021 6:22 pm
Depends what type, Hope one goes on the fork with a crown setting tool or makeshift tools then the crown race slots on top if it's a split version otherwise it's tooltime again, that's a two piece option, the second is a split crown reducer from the likes of nukeproof or superstar that pops on a 1 1/8 steerer without tools and slots into 1.5 headset, just make sure the bearing internal degree 36 or 45 matches the crown race.
Posted : 30/06/2021 8:58 pm
Ok - I've ordered the Hope one, as if I ever replace the headset I'll probably buy Hope 🙂
Will see if I can make it fit...
Posted : 30/06/2021 9:06 pm
It's a bastard to fit but from what I understand it's safe enough to cut a slit in it, there was another topic at one point, I think @scotroutes had one?
Posted : 30/06/2021 9:08 pm
I've found the Hope one easy to fit and remove because it's quite big so you have plenty to hit without going near the fork crown or steerer
Posted : 30/06/2021 9:12 pm
