Headset headache!
[Closed] Headset headache!
[#7872102]
Hi all,
I'm sure it has been asked before but can anyone tell me what headset I need for a Giant Anthem X with a standard Fox tapered steerer?
Everytime I think I know, it turns out I don't!
Thanks
Posted : 06/06/2016 10:16 pm
For the original fork it came with or a new one - if it's a new one, Take the headset out and measure the internal diameter of the headtube?
It probably got an. 'overdive' headset and fork so 1&1/4 top bearing and 1&1/5 lower. However the headtube diameter is same as a standard 44/56 (I think).
Posted : 06/06/2016 10:31 pm
Check the frame to see if it has a Overdrive or Overdrive 2 transfer on it,near head tube usually.
Overdrive is a standard tapered internal headset,1" 1/8 top with a 1.5 bottom.
Overdrive 2 use's 1" 1/4 top and 1.5 bottom.
Use the same frame but Overdrive 2 frames use different top cup,stem and steerer.
Thanks,
Max
Posted : 06/06/2016 11:00 pm
It doesn't come with a headset but on the outside it says overdrive.
The fork is not a factory built in fork so just a standard taper, 1 1/8" to 1 1/5".
I assume it is an integrated? Or semi integrated? And I know it needs to be zero stack..
Thanks guys
Posted : 07/06/2016 6:35 am
Semi integrated, you need a ZS44/28.6 top cup and a ZS56/40 bottom cup.
Posted : 07/06/2016 7:01 am
Sweet i'll get that ordered. Thanks for your help!
Posted : 07/06/2016 7:48 am
