I need to fit a new headset and don't have any specific tools for the job. What's the easiest way to do it without spending a bunch of cash on a press and a crown race tool? I was thinking for the headset, a couple of planks and some tapping with a mallet but I'm a bit stuck on the race.
max, I have a headset press...
for the crown race I've always fitted them using a bit of plastic pipe from B&Q and just knocked them down with that.
Heat the crown race first in boiling water - it makes it go on easier
A piece of threaded rod from B&Q, two nuts and two large washers/plates... For the race as said just a bit of pipe slightly bigger than the steerer.
piece of wood and a big hammer
ideally the pipe is made of something weaker than the crown race so it gets damaged and not the race...
ie plastic plumbing pipe as suggested earlier.
