I don't like star nuts, I prefer the Hed Doctor.
This FSA one looks the same as Hope, but cheaper.
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=2218 ]http://www.chainreactioncycles.com/Models.aspx?ModelID=2218[/url]
It says it's for carbon forks though.
Are carbon steerer tubes a different inside diameter to aluminium, or will it fit the same ?
Someone must know. 😕
Yeh it'll work. I've used a similar one on an ali steerer.
The one I fished out of my carbon road steerer was a metal wegde assembly like above - just dont over tighten it!
Thanks Gary.
Foxy, did it then fit in an ali steerer ? Not that I don't beleive Gary, it's just that it's nice to have a second opinion. 🙂
TBH I am not sure - I took it out but have not tried in my alu steerer as already had a hope head doctor and my new carbon road frame came with a "bung" it certainly wont a be bigger diameter than a std head doctor so you may have to crank it tighter?
What about this:
http://www.chickencycles.co.uk/index.php?cat=4&sub=106
Carbon steerers tend to be a lot thicker than alloy ones, so it may not tighten sufficiently.
Why would the one in that link be any different?
It might be a smaller diameter to better fit thicker steerer tubes.
Not certain, just a possibility.
or one from parker:
For internal diameters from 23.5 to 25.4 mm
[url= http://www.parker-international.co.uk/6473/Pro-Headset-Expander-Cap-11-8-.html ]Linky[/url]
Gary I was comparing them as one in the list said fits both alloy and carbon steerers!
Scroll down the list 🙂
Why do you keep adding links to headset bungs for carbon steerers, the op is using an aluminium steerer.
Just trying to find a cheep bung and to answer his question Gary?
i.e. one says : For internal diameters from 23.5 to 25.4 mm
so maybe he can go measure it?
Fair enough, but the 2 I've used fit ali steeres
OK Gary - he just wanted another person to say yes before he went for it - I was just trying also to say it should be OK 🙂
You could always use one of these from USE
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=2741 ]Ring-Go-Star[/url]
Suppose he could always send it back. Think I used the one inch M:part one from wiggle.
Thanks for the replies, looks like it's worth a try then as some expanders fit both carbon and ali, they must all be near enough the same size.
If you want a genuine hed doctor cheap, we've got a few in our workshop, prob do you one for £4 posted.e-mail me if interested.
I've a hed dr type bung from some carbon CX forks - £4 posted if anyone wants it.
