Headset cups remova...
[Closed] Headset cups removal,is it easy?
[#3393621]
I,ve got the right tool,do i just go at it with a hammer,any tips?
Posted : 26/11/2011 10:08 am
take your time
Posted : 26/11/2011 10:16 am
Use a suitable drift and give a good whack, should come out easily enough. If you have a vice then clamp the head set and twist the frame.
Posted : 26/11/2011 10:17 am
I wouldn't clamp the cups in a vice if you want to reuse them
Posted : 26/11/2011 10:28 am
If you've got the right tool, then yes - pop it in and hammer away. If you're doing it with a drift or similar, then go slowly and tap opposite sides.
Posted : 26/11/2011 10:29 am
Get a bigger hammer.
Posted : 26/11/2011 10:31 am
i like the look of these supertat hs removal tools. anyone used one ?
Posted : 26/11/2011 10:33 am
And a bigger drill.
Tomorrows post....Any tips for headset cup installation.
Followed by.....My headtube does'nt look round anymore.
And finally....For sale,frame with slight headtube damage.
Posted : 26/11/2011 10:50 am
trailmonkey - looks identical to the Park one I use. They're all much of a muchness, probably.
Posted : 26/11/2011 10:56 am
I've got a superstar one, does exactly what it says on the tin!
Posted : 26/11/2011 11:25 am
 DrP
I just use a bit of (soft) metal pipe, tapping either side bit by bit..
Takes about 6 taps to get it out...
Can leave the frame in a work stand as it's the 'shock' that drives it out...
DrP
Posted : 26/11/2011 11:33 am
Thanks everyone,except rorschach (only because me may well be right :D)
Posted : 26/11/2011 12:02 pm
I use an old metal bracket and a hammer. Never failed yet.
Posted : 26/11/2011 12:04 pm
The tool pictured shouldnt need a hammer. Drop it onto the cup a couple of times and it should pop out.
Posted : 26/11/2011 12:25 pm
If your using the correct tool, the only thing to watch for, is where the cups fly to when they leave the frame; dependant on how well they were installed in the first place.
Using that design of tool should need a hammer, the superstar one looks to be springy steel and will probably bounce if dropped on the races, the Cyclus one is more heavy duty, but still needs a dead blow hammer.
Posted : 26/11/2011 12:35 pm
For top marks you have to catch the top cup in your hand when it pops out of the frame.......or better still in your apron pocket like what I do :0) . Cytec level 4 shizzle that is .
Posted : 26/11/2011 1:02 pm
