headset cup removal...
[Closed] headset cup removal ?? advise needed
[#2540730]
howdy, sending a orange 5 frame off for a respray soon
wondering whats the best way to remove hope HS cups without having a specific tool, want to keep the cups in good condition for re-use as its in great condition
a slight tap, working around the internal edges with a bit of wooden broom handle offcut was the method i used the last time i did this many years ago but that was with a disposable HS
any advise is welcomed, thanx in advance, kev.
Posted : 07/03/2011 11:22 pm
 Olly
broom handle, old screw driver, its much the same.
i would suggest, going to the bike shop and fluttering your eyelashes from behind a fiver.
with the proper tool, its safe, and is a 10 second job.
tool in > SMACK with massive hammer
job done.
Posted : 07/03/2011 11:24 pm
What Olly said. Risk knackering your frame for a fiver? No. (Says me thats done it on loads of frames)
Posted : 07/03/2011 11:26 pm
I've removed a hope with a socket and extension bar. largest socket that fits through the upper cup, tap-move-tap-move-tap-plonk. then up one size on the socket and whack the other cup out. Didn't harm the headset, but take it steady.
nice 1 chaps,
re-
didnt think of the socketset option but might see if the lads in the LBS will do it for me as i will be getting them to re-fit it anyway.
rgrds, kev
Posted : 07/03/2011 11:31 pm
 Olly
or you could buy the tool for a tenner off fleabay
should be pretty self explanatory.
cant be all that difficile to make really!
section of copper or plastic pipe with the slots in and a bung to splay it out might work, but wouldnt last too long.
Posted : 07/03/2011 11:35 pm
fit with a large hammer....I've done Hope into nice frame that way....was a bit nervy mind.
Last one I fitted (in a ti frame) was done with a long bolt and a couple of large washers - a sort of home made press basically.
Posted : 07/03/2011 11:37 pm
