Headset confusion :...
[Closed] Headset confusion :/
[#7211001]
This is melting my brain everso slightly…
I know there are loads of threads about this cos I’ve found them – but I’m still confused!
Being a dedicated follower of fashion and not at all behind the times I’ve just bought myself a 2010 Spesh SX (not Trail) with a tapered headtube, & some straight 1 1/8 Lyriks; the top headset cup is easy-peasy (“normal” in my world), but the bottom not so much.
I got the straight steerer forks as I believe I can use a zero-stack bottom cup, thus maximising the potential travel available that an external (normal) one would reduce slightly (uturn forks, so easy to find the sweet-spot). I’m not sure whether this is correct, however, as I don’t recall the bottom of the HT having a recess for the cup to sit in (the frame is at the LBS being faced) Am I getting mixed-up with integral/integrated here and integral (the type I think I need) doesn’t require a recess?
I *think* I need a ZS49/30 – or maybe a ZS49/40 with a reducer for future use if I ever have tapered forks. Not sure Hope do ZS49/40?? And it would be nice if it were Hope, but I can live with FSA 🙂
Ta.
Posted : 23/07/2015 8:22 am
I'd just confirm the fitting you need and ask Hope.
Posted : 23/07/2015 8:29 am
I'd look at that and ask here - which is what I did :mrgreen:
Edit: This on e is even more helpful, but somehow I still don't quite get it 🙂
Posted : 23/07/2015 8:31 am
Straight steerer you're looking at something that ends in 30. 30mm is a bit bigger than 1.125" cos the crown race needs to be a tight fit innit
The other half of the equation is the ID of your Spesh headtube at the bottom. If it's 49 or 44 you need a ZS49 or 44/30. If it's 55 or 56 there aren't any Hope 55/30s or 56/30s so it'll have to be a 55 or 56/40 with the reducer
ZS49/40s do exist (FSA/FireEye) but they're pure evil - 40 mm steerer inside a 49 mm headtube doesn't leave much room for the bearings. Hope's EC49/40 is an animal with huge bearings highly recommended
HTH
Posted : 23/07/2015 9:08 am
Cheers rocketman - that helps a lot 🙂 Have ordered a couple & if they don't do it then at least I'll know what the answer is as there'll only be one alternative left 🙂
Posted : 23/07/2015 10:14 am
