headset bearings in...
[Closed] headset bearings in carbon frames
 MSP
[#9437584]
Fitting a fit a new frame where the headset bearings just sit directly against the carbon, wondering if to leave dry, grease or put a bit of carbon paste?
Posted : 15/07/2017 4:37 pm
 tish
I have always used grease and never had an issue in mine.
Edit that's with hope pick and mix.
Posted : 15/07/2017 4:49 pm
grease here too
Posted : 15/07/2017 4:51 pm
 MSP
Hope pick and mix have bearing cups, in this case the cups are the carbon frame.
Posted : 15/07/2017 5:13 pm
You don't want the bearing moving relative to the frame so I wouldn't grease it. I left mine dry. Carbon paste might not be a bad idea if you have some handy.
Posted : 15/07/2017 5:23 pm
 tish
Sorry I read it wrong that's why I stuck the edit in
Posted : 15/07/2017 5:32 pm
Don't use friction paste unless you never want to remove the bearing....
Posted : 15/07/2017 5:33 pm
it won't move, there will be a lot less friction in the bearing than the mating surface even when greased
Posted : 15/07/2017 5:42 pm
 Kuco
Asked bike shop the other day about this and they said lightly grease it.
Posted : 15/07/2017 6:42 pm
Always grease as it prolongs bearing life.
Some greases may be bad for the Carbon/resin mix, but Park for example state that their's is fine to use on carbon.
Posted : 15/07/2017 6:43 pm
I emailed YT about this scenario and they said to use a carbon friendly grease.
Posted : 15/07/2017 6:51 pm
Suitable grease; stops corrosion between the frame and cups (see any number of stuck seatpost threads)
Edit: just re-read the OP, non-stainless bearings will rust, and any type will have a galvanic reaction with CF in time so I would still grease
Posted : 16/07/2017 6:37 am
