Headset bearings fo...
[Closed] Headset bearings for 2011 Spesh Epic?
[#6305041]
I'm looking to replace the headset bearings on my 2011 epic elite, but after ordering some from edge sports I found that the upper campy style bearing doesn't quite fit, as although the bearing height is the same, there's a step between the outer bearing casing and inner casing, which the edge bearing doesn't have, so I cannot tighten the cover down to cover the entire bearing.
Does anyone know where I can get an upper bearing to do the job that doesn't cost a fortune for a 2 quid bearing?
Posted : 29/06/2014 10:22 pm
I replaced my stumpy ones which I belive are exactly the same with a lower one from Superstar (as per advice on here) and the upper one with this from UK bike store, and they were correct
http://www.ukbikestore.co.uk/product/402/160_6480/fsa-th-870-mr042-1-18-acb-45-x-45-campag-headset-bearing.html
Posted : 30/06/2014 11:21 am
As I mentioned in another thread - get the code from the race and order through BETD - worked for my 2008 Enduro
Posted : 30/06/2014 12:04 pm
