Head tube, headset ...
[Closed] Head tube, headset & fork steeter size HELP!!
[#9616150]
[url= https://farm5.staticflickr.com/4472/37519243930_359f265517_z.jp g" target="_blank">https://farm5.staticflickr.com/4472/37519243930_359f265517_z.jp g"/> [/img][/url][url= https://flic.kr/p/ZarW53 ]30mm head tube[/url] by [url= https://www.flickr.com/photos/155441013@N05/ ]SIMON ASQUITH[/url], on Flickr
I,ve decided to restore my 1980's giant bike but its been easier to bang my head against a brick wall thatn trying to search and find out what size headset and fork steer size I need.
Am I right in thinking that I need a 1" headset and a 1" steer fork?
Posted : 18/10/2017 6:53 pm
Translate to Imperial to get 1 1/8" headset, standard size for that age
Posted : 18/10/2017 6:57 pm
no it's not a 1 1/8th headset you'll need ...30mm is not 1 1/8th and anyhow headset required refers to the steerer tube OD .
I'd imagine it originally had a fork with a threaded 1 inch steerer tube and a 1 inch threaded headset . gets a little complicated as iirc there were two 1 inch threaded headset sizes ( tiny difference ) ISO and JIS .
which fitted 30 and 30.2 ID headtubes and different crown race sizes.
Have a look [url= https://www.sheldonbrown.com/cribsheet-headsets.html ]here[/url] for more info on sizes.
I'm happy to be corrected if anyone disagrees
HTH
Bill
Posted : 18/10/2017 10:13 pm
1 1/8" was not used on Giants in the 80s.
Kaiser is most probably correct.
It would have originally been fitted with something like this:
https://www.sjscycles.co.uk/headsets/tange-levin-cds-1-inch-chrome-steel-cup-threaded-headset/
Posted : 18/10/2017 10:30 pm
bear in mind if the ID is 30mm as it looks ( rather than 30.2 ) the headset linked to above would not fit ..as it's a 30.2 cup .DJ is just using it as an example of the type .
Posted : 18/10/2017 10:39 pm
Thanks for input everyone. it was a thread headset/fork but ideally am wanting to replace everything with a none-thread headset and a new 1" rigid forks.
Think this is the correct info I need
[url= https://farm5.staticflickr.com/4480/23936044218_ae383d4d30_z.jp g" target="_blank">https://farm5.staticflickr.com/4480/23936044218_ae383d4d30_z.jp g"/> [/img][/url][url= https://flic.kr/p/Ct9u2y ]Capture1[/url] by [url= https://www.flickr.com/photos/155441013@N05/ ]SIMON ASQUITH[/url], on Flickr
Posted : 19/10/2017 9:26 am
Can you borrow a vernier caliper with tube I/D 'tongs' ?
Even then, it's not going to be easy to distinguish between 30.0mm and 30.2mm, unless it's a nicely machined head-tube.
Where can you buy new 1" thread-less steerer MTB forks then ?
Posted : 19/10/2017 3:31 pm
Here are some 1" steerer forks:
[url= http://www.carboncycles.cc/?s=0&t=0&rb=14& ]
http://www.carboncycles.cc/?s=0&t=0&rb=14& [/url]
Posted : 19/10/2017 3:47 pm
