Have I got this rig...
[Closed] Have I got this right?
 marc
[#2089807]
Never one to chuck me cash about, but I think I should upgrade my fork. It's a seven year old Pace RC36 100mm holding up a 2001 Tracer.
I've always used Pace forks, but I'm fed up with them going solid as soon as the temps drop or there's a light drizzle in the air. And Adrians flogged that side of things, so I won't be embarrased if I bump into him.
A bit of browsing tells me that the frame was designed to run with 100mm forks (which were long travel back then!) which would give head angles of around 71.5* or 70.5* (you can adjust it), also that increasing travel on the forks slackens those angles by 1* every 10mm.
So, if I put 120mm forks on the head angle would change to 69.5*, yes? If so, would this bugger up the handling? Can you feel a difference of 1*?
Posted : 15/10/2010 9:37 am
wouldn't worry about the slight slackening, the biggest noticable thing will be how much better new forks works especially if you get a bolt through axle
Posted : 15/10/2010 9:42 am
I think it's roughly one degree of slackening per inch of extra travel, not per 10mm.
I doubt you'd notice the difference in handling particularly and if you do, you can always run a bit more sag.
Posted : 15/10/2010 10:15 am
 marc
That's good, so I can look up to 140mm 😉
Won't a bolt through mean a new front wheel though?
Posted : 15/10/2010 10:57 am
I've got a 2001 Tracer. They have a reputation for having a high bottom bracket. A longer fork would make that worse. The rear has two travel settings to suit either 100mm or 80mm. It it was me, i'd match it to a fox float and drop the travel down to 100mm.
Posted : 15/10/2010 12:05 pm
Gets some RS Reba's or older Rev's and play with the all-travel spacers?
I'd agree with onzadog - especially if the BB is high to start with.
140 from 100mm is a huge jump, 120mm might be more reasonable/useable though.
Posted : 15/10/2010 12:09 pm
 marc
I was a bit tounge in cheek about 140mm.
Onzadog, have you tried slightly longer forks on it? You have got me thinking though; Chain Reaction have an '09 32 F100 RL in the sales that could do the job.
Before that I'd been looking at the Rockshox Revelation Team Uturn 120/150 that On-One had going cheap.
Posted : 15/10/2010 1:22 pm
I ran forks at 80 and at 100 but nothing longer. I did feels that 100 mm really was the limit though.
Posted : 15/10/2010 7:35 pm
