Have a look at my c...
[Closed] Have a look at my crack
[#10778449]
There is a crack in my Chameleon’s seat tube by the clamp.
See picture :
I was thinking of drilling a hole to stop the crack expanding further and covering it with a double bolt clamp- out of sight out of mind.
Alternatively would it be possible to get this tig welded?
Not sure how wise it would be to drill a hole where the post is being clamped.
Posted : 22/08/2019 11:18 pm
Cut it off at that point and cut a new slot below for when you move the seat collar down.
Looks like enough room for collar to sit below crack, yeah?
Posted : 22/08/2019 11:23 pm
I can’t cut it off there as it is level with the welds on the top tube/front, so not enough room. 🙁
Posted : 22/08/2019 11:29 pm
What size frame. I have a 26" medium hung up in the garage just waiting for a new home
Posted : 22/08/2019 11:36 pm
Is it just a paint chip on the LHS or is that another crack forming?
Posted : 22/08/2019 11:37 pm
I'd do your first option (drill and big clamp) and see what it does / how it grows.
Partly cut down and big clamp would be my second option / something to try if it still grows.
Welding will just crack again.
I now don't make (steel) frames with lots of exposed seat tube above top tube because they tend to crack if not very thick / sleeved. I did the cut off and lower collar on one of my early frames which I still commute on - meet the offcut Cracky McCrackface:
[url= https://i.postimg.cc/W3tJfpQs/DSC-0582.jp g" target="_blank">https://i.postimg.cc/W3tJfpQs/DSC-0582.jp g"/> [/img][/url][url= https://postimages.org/ ]upload pic[/url]
Posted : 22/08/2019 11:41 pm
A paint chip...
Thanks for the offer Tracey. I believe this one is a small/26. I bought it used as a jump bike off eBay to join my son at the pump track.
Can’t return it though as I paid cash and it’s a 300 mile round trip (impulse buy whilst working away).
How much would you want for your frame?
Posted : 22/08/2019 11:55 pm
Of course you could always just epoxy your seat post in position so you could just cut off the excess clamp area.
Think of it as a type of contemporary Drillium.
Posted : 23/08/2019 4:13 am
I asked the same question earlier in the year - various suggestions, but I ended up drilling the cracks and bonding a shim in. Haven't used it yet, but it'l be a 27.2 seatpost when I do.
[img] v[/img]
Posted : 23/08/2019 8:33 am
Looking for £90 + postage.
Posted : 23/08/2019 9:45 am
What width is the seat post? As above, bond a sleeve into it and fit a 27.2 seat post and get a good deep seat post collar and forget about it. Cover it with a sticker and pretend it's not there. Use a long seatpost to reduce the stress.
Posted : 23/08/2019 10:13 am
Get a seat clamp without the lip, like MT ZOOM ultralight, slide it down over the crack,no need to cut down seattube and use it under your other clamp.
Posted : 23/08/2019 8:12 pm
What Robo said. Or alternatively, you may be able to source a "double height" seat clamp with two bolts on it - I know DMR used to make one (years ago).
When this happened to me (lower down the seat tube), I cut a seat post flush with the top of the seat tube, and used a thinner post in the inside of the cut post. Totes ghetto but it kept me rolling. Yours doesn't look that bad though 🙂
Posted : 24/08/2019 8:50 am
Didn't the Chameleon come with a l lifetime frame warranty?
Posted : 24/08/2019 11:22 am
How did that address the crack propagating, and how did you hold the thinner post in position (assuming you didn't slot the cut down post)?
Posted : 26/08/2019 8:51 am
