Found myself at a buying point. Not sure what to go with? Any recommendations?
What sort of riding do you do?
Trail centre?
Down hill?
Canal Tow Paths?
A good salesman would say you're actually a fair way off 'buying point' )
Good Point Jameso 🙂
Good Point Jameso 🙂
Riding style, nothing to technical as I live on the Essex/suffolk border so Thetford etc but I do manage to get away to the Lakes and the North Yorks for proper riding but not trail centre riding.
For rigid I have found my 29er far more capable. even with 1.9" tyres compared to 2.2" tyres/
Might not be as much fun possibly.
It's more about 'how' you like to ride, than 'where' imo. Any reason not to consider a 29" HT as the 3rd option?
Cost mainly, at the moment I'm running a pair of Fox Talas that are always on lock out. So I'm questioning myself if I need suspension with the comfort of a 29er.
I'm riding a Kona Explosif at the moment but as nice as it is I miss my old P7 which I have and am considering getting that resprayed and then building that up with my current set up or just take the plunge and go 29er now and possibly get some suspension forks at a later date if needed?
I'm nowhere near at buying point am I 😉
Do you like exploding wheels?
What about 650b?, you may be able to fit the bigger wheel in your existing Talas.
Well I'm a big believer in rigid bikes that are short forked / rigid-specific, but a rigid non-euro-jey 29er that can take a 100mm fork one day sounds ideal otherwise. Unless you go for a 26 that is )
rigid 29er.....suprisingly spry and compliant
26er with 140 plus forks.....suprisingly silly and daft
so both
You've just answered your own question. The answer, as with a lot of things, is an Orange P7
I've gone from a 26" wheel at the front of my rigid bike to a 29" wheel and there is no doubt it's more comfortable. I wouldn't equate it to suspension though. The nearest thing to it I find is getting to the end of a section on my hardtail thinking it was a bit bumpy and realizing that's because the Rebas are still locked out. In other words I reckon it's similar to having 20mm or so of movement
Being 5'5" I'm not likely to be buying a 29 suspension bike but I would now look at 29 rigid specific bikes if the current frame ever needs replacing.
