had a rear wheel puncture this morning.......minus 5 on my phone.
tyre was muddy/wet from side of the road slurry/slush.
took the wheel out, got tyre levers ready....but my hands were to cold to do anything.
took me 35 mins cos i had to get stopping to try to warm my fingers.
i hate cycling sometimes..... 😡
this is why my commuter tires weigh 1kg each.
take some latex gloves in your pack to, helps a bit
I can remember the abject misery and pain induced by fixing a puncture on my old Dawes 5 spd in -5 deg temp when I was about 15. The worst bit was trying to get the glue to cure.
I always worry about having to fix a puncture when out in sub zero conditions so I take a couple of heat packs with me, they are thin enough to slip in a cycling jersey pocket and take seconds to heat up. You can get a pack of 5 on ebay for next to nothing. Never had to use one yet but I am going out tonight......
something like this
http://www.ebay.co.uk/itm/AIR-ACTIVATED-INSTANT-HEAT-PACKS-HAND-WARMERS-PACK-OF-4-/190782464738?pt=UK_SportingGoods_OtherSports&hash=item2c6b8562e2
Latex gloves. Should be part of your kit anyway, in case of dog eggs. Although at this time of year I use glove liners and can easily work whilst wearing just those.
And by "mend a puncture" I hope you mean "replace a tube".
Plus 1 for what Jekyll said. Heat packs easy enough to stash in your bag
Cast your mind back a few months ..Ton ......even shit cycling is better than no cycling 😛
What about tubeless ??
I carry a can of that puncture gunk stuff from on-one on my commute. Normally wouldn't go near it, but better that than walk home or faff about in the cold.
deffo mate.... 😆
thought about tubeless......is it that good?
Tubeless is great ......I've not had flat since going tubeless about 2 years ago ...also you can pretty much go tubeless with most tyre/wheel combo Just do it ghetto to start with
http://m.youtube.com/#/watch?v=WRM7gq1fcoQ&desktop_uri=%2Fwatch%3Fv%3DWRM7gq1fcoQ
we went to afan in november and got to the top of whites are there was 4 guys there fixing a snapped chain and they could not put a quick link back on as there hands were so cold, took me 2 seconds lol.
FFS!....M....T....F......U 🙄
Spare tube for me. I can repair the puncture at home in the warm.
Unless I get two punctures...
Yep latex gloves here too, but not much use if your hands are already a bit chilly. Does stop them getting wet though.
I had exactly the same thing last night. Made worse by not being able to pull the thorn out, as the metal multi-tool sucked all the heat out of my hands.
Last night decided to put some latex gloves in saddlebag - glad other recommend it.
Panda
It wasn't those puncture proof tyres I sold you was it?
Your phone has a thermometer app?
Latex gloves plus hand warmer for me when its like this.
Share your pain luvvie, share your pain.
I'd take a spare tube, far better to slam one in than fek around with glue that doesn't bond or busted fingernails..
Same reason I rode 15 out of 25 miles with no front brake pads on Saturday. No way was I attempting to change them out on the trails in those arctic conditions :(.
It certainly reduces incidence in my experience:
* Thorn prick type punctures often self-seal. You may not notice - or the tyre may soften then seal, you investigate and just add some more air.
* Snake bites are rarer.
* Tyre slashes can often be repaired with a TL repair kit, without taking the tyre off or the wheel out of the frame even.
If all the above fail, just whack a tube in, which is no bigger a deal than fixing a tube flat. (But make sure you check the inside of the tyre for thorns that may have self-sealed, but are still there so would flat a new tube on inflation).
Caveat: some tyres can be very tight on tubeless rims. I wouldn't run a tyre that I couldn't get off the rim trailside.
A search will show up gazillions of threads on this.
Changed to mud tyres the other day; at least 15 thorns and a barbed fishing hook between the ones I took off.
Maxxis LUST go on nice and easy (usually).
Aren't you supposed to pee on them to thaw them out or something?
I limped the last half mile home the other day just to avoid having to fix the slow rear flat on my commuter...
Would latex solution in a 25c road tube @90-100psi do anything useful to reseal a flat? most of the flats I've had on the road bike have been due to cuts/slashes in the tyre, suggesting winter road debris is the biggest menace right now on my commute.
or better yet I'm still toying with the idea of trialing a ghetto tubeless tyre on the road bike as it's worked well for me on the MTBs, but I don't tend to see the type of cutting you get on a road tyre on my MTB tyres pinches and thorns aren't the issue it's flint and glass so I don't know how a tubeless road setup would actually fair against that...
Did you happen to be wearing that natty little Balaclava Ton?
This year at mountain mayhem in a downpour at 2am-not too cold but f*cking miserable.
latex gloves - good idea
Back in November, furthest point from humanity. (Under the TV mast at Hopwas, nr Tamworth). Multiple thorn attack. Tube I'd grabbed on the way out was a 20" for my lads bike. With freezing hands I managed to get it into a 29" tyre...breifly. Went pop as soon as I rode it. I chickened out of stuffing the tyre full of grass & phoned my brother. 🙂
Smug, or what. Tubeless 5 Spot. Nuff said
I went tubeless back in the summer on my P7 commuter, no flats since. I do however carry spare latex gloves, two tubes, co2 canisters and a pump. Don't care how much it weighs, its all good training and I only want to be up and running asap if i do flat.
