Handlebars, how wid...
[Closed] Handlebars, how wide is too wide?
Not so much a magic formula but at least a good starting point as far as set up is concerned (especially for new bikes with diff geo to your other bikes). Unless you have an abundance of differing stems, bars it can be quite difficult and potentially expensive if you get it wrong.
It's either that or pay for a bike fitting. My brother in law paid £120(?!) for his but reckoned it was the best money he's spent.
Posted : 04/01/2014 8:46 am
You riding xc/trails? at 6' I don't know why you would want to ride with a bar width of 680mm unless it just tame bridleways etc you're riding. I think a wider bar enables more leverage which equates to less force being needed to hold the bars straight at high speed when you hit something that tries to pry the bars from your grip.
Amazing post! You're riding Swinley FFS! I bet you high five and say rad and sick a lot at the bottom of every section.
I'm not even totally sure what mine are, 660 rings a bell. They're fine. Borrowed a bike with narrow flat bars last week, and it felt horrible.
Posted : 04/01/2014 9:58 am
No one, I said NO ONE should be riding under 750mm.......well that's what the mags say..!
Posted : 04/01/2014 10:04 am
My fs came with 720mm and a 90mm stem. When I was using that bike for everything I left it like that. Now I have a 29er ht for xc stuff (700mm flat bars with bar ends BTW) I dropped to a 50mm stem. Massive difference so might go to 740/750mm in the future.
Posted : 04/01/2014 10:47 am
It's only too ride if it's a detriment to your riding.
Like if you can't get the bike out of the door 😉
Posted : 04/01/2014 11:08 am
To be honest I am thinking about upgrading from my modest 580mm bars to something a little wider. I cant fit my bell onto my current set up after fitting my reverb post remote, plus then I will be in the cool gang 🙂
Posted : 04/01/2014 11:12 am
Wider than this
or to get through this tree jump
i.e. 750 is just about the limit here 😀
Though if I can learn to wiggle through, wider can be achieved.
Posted : 04/01/2014 12:41 pm
I bought my bar with the intention of cutting it down. I'd previously ridden bars at around 710mm but because I used Hayes brakes with longish blades for one finger braking, the levers were miles down the bar still hence I went wider.
Once I'd ridden them a few times I liked the extra width so the bars remained uncut. Nothing with trying to be cool or owt and yo be honest for the places that I ride, they don't cause too many issues.
Posted : 04/01/2014 12:51 pm
710 felt to wide on my soul with 70mm stem, dropped to 685 and its perfect.
They feel great on the Enduro with a 50mm though.
Posted : 04/01/2014 12:56 pm
I ride a deeply unfashionable bike anyway. A 26in wheeled,slimmish tyred, shortish travel forked, slightly racy geometry, fillet brazed steel Saracen.
685mm is plenty wide enough for me thanks. I want to hold something that feels like a handlebar not a flippin' rudder.....
Posted : 04/01/2014 1:17 pm
If you learn to lean the bike, not yourself, when cornering (with correct footwork), long bars and short stem starts to make sense. Push the bar down to lean.
Went 750 on the full sus and loved it but kept 685 on the hard tail for a while thinking that I tended to be a bit more xc-ish on it. I ended up going 750 also though as it just felt way too short in the end, being used to 750 on the full sus. Plus the hard tail is pretty slack and I ride a lot of the same stuff I do on the full sus on it also.
Posted : 04/01/2014 2:25 pm
Of course it depends what you ride and how you ride it, and how you are built (shoulder width, arm length etc)
But i'd say, try it, you might like it!
One thing i really noticed on a swap from a 75mm stem/690mm bar combo to a 50mm stem/750mm bar combo was that not only was there more "leverage" but the higher moment of inertia caused by your heavy hands and upper arms being pushed out further from the center of rotation mean't a lot more stability too in the choppy stuff! (kinda like a steering damper!)
When pushing hard into flat and bermed turns, that moment as you feel for front end grip and the handlebar turning loads sort of reverse a bit(as the tyres loads/slips) seem to be a lot easier to feel and "ride through" with the wider set up, and the front wheel felt a lot less likely to "tuck under" quickly.
Posted : 04/01/2014 3:25 pm
@njee20 you're a dick!
Yes at 48 I use the words rad and sick frequently & have only ever ridden Swinley. I wish I was brilliant like you. I'm sure your wife loves you very much.
Posted : 04/01/2014 3:30 pm
Chill, from your post you did deserve it.
Posted : 04/01/2014 3:54 pm
What part of my post deserved ridicule?
Posted : 04/01/2014 7:08 pm
To be fair (having ridden with him) he's a very VERY fast and skilful dick to be precise. I'd wager he'd rip you to bits on pretty much any trail you care to mention.
You did come over as rather scornful to be honest mate, I imagine you've not been MTBing very long by the sounds of it?
Deadkenny - I know EXACTLY where you took both of those pics. I rode over that very canal a few days ago. You must be local to me. 🙂
Posted : 04/01/2014 7:40 pm
All 3 bikes currently at 740. Too many trees locally to try wider - I clip enough of them as it is.
Posted : 04/01/2014 7:50 pm
njee possibly does deserve a slagging for rising to such an obvious troll but that's all...
Posted : 04/01/2014 7:51 pm
@ peterpoddy..no scorn intended in my post to 2unfit 2ride & I'm sure njee20 is the fastest...doesnt make him any less a dick though for ridiculing someone who has offered up an opinion. He didn't try to contribute to the op's question whatsoever.
Posted : 04/01/2014 7:55 pm
When you either lose more speed from mincing between trees than you gain from the extra control due to your awesome wide bars or when you crash more often from clipping trees than you avoid crashes by catching sketchy moments due to your awesome wide bars, that's how wide is too wide.
Or when it just feels stupid and you can't steer super-tight super-slow corners without feeling like your arms are too short.
Posted : 04/01/2014 8:03 pm
 Euro
720 is a good intro to the cool wide bars gang imo. Wide enough to feel the differences without getting too cool. I've a set on my hardtail and they're spot on temperature wise. I tried my Renthals at 780 in the shop but didn't like them, so chopped them to 750 on the FS. It's definitely a very personal thing though, as i've seen guys much smaller than me (that's most folk) look comfortable on a far wider bar. OP - try them for a few weeks at 720 and see how you get on. £1 says you'll like it 😀
Posted : 04/01/2014 8:10 pm
PeterPoddy - Member
Yeah, I'm in Woking and have the playgrounds of Surrey Hills, TH/Porridgepot/Frith, Caesars, Minley, etc, as well as the motorways of Swinley of course, all surrounding me. 😀
Was over the canal yesterday. Still can't ride through with those bars though without clipping them.
Posted : 04/01/2014 8:24 pm
Crikey, my apologies for upsetting you Tymbian, you did offer up a rather peculiar opinion which read like you'd taken magazine articles as gospel! PP's doing me a disservice, I'm not that quick, I'll take his kind words though 😉
Indeed, I looked at the picture of Clawhammer for about 2 minutes, whistfully thinking of dry trails. Happy times!
I'd be interested to try some wider bars, but must say that most people just look like they're fighting with the bike when they get to >750 or so, which is surely the opposite to what one is trying to achieve.
Posted : 04/01/2014 8:53 pm
 core
The original bars on my bike (genesis core) were 660mm, I'm pretty broad shouldered, 6ft tall, and always felt the bars were narrow and I was curling my hands over the ends.
I got some 740mm bars (with thoughts of trying them & probably cutting them down), but really like them as they are, feels much nicer on technical stuff. I do use grips with double lock on rings though, so probably stay a little inboard for comfort.
Posted : 04/01/2014 11:32 pm
I went from 660 to 780mm, and feel to have a lot more stability, even with a 20mm shorter stem I feel to hsve s better weighted front end. Tempted to try something a little wider just to see how it feels.
Posted : 05/01/2014 12:29 am
Well this thread has certainly stirred debate & some interesting opinions.
FWIW I have never felt lack of stability with my current set up, maybe I'm unique, but chances are 680mm is quite wide enough to keep control below warpspeed, but conversely I remember going up from silly narrow bars where the brake levers were but a few inches apart & thinking that this was the future.
I think the safest option is to suck it & see.
Cheers all 🙂
Posted : 05/01/2014 12:45 am
I went from 711mm (for ages), tried 785mm for a while, was ok but the bike did feel sluggish on tighter trails, despite a short (50 then 35mm) stem. Tried a 740 and 750 on demo bikes and they seem much better so going for that next I think.
Posted : 05/01/2014 12:47 am
chiefgrooveguru has the answer
Posted : 05/01/2014 1:00 am
Went from 80stem/670bar to 50/740 on my zesty. Felt good. Would never ride below 700 anymore.
Now I ride an enduro with 60/720 and it gives me more confidence on woodsy trails. Don't worry that much bashing the handlebars into trees.
Nice open area however I would not hesitate to go back to 740 or even try 760. Anything more than that... I just feel ridiculous.
5'8" with definietly wide shoulders.
Posted : 05/01/2014 1:08 pm
Page 2 / 2
