howwwwwwwww many cables! 😈
Still looks quite odd.
you cant polish a turd but you can cover it in glitter 😉
five............ do I get a prize
5 all in... brakes, front/rear shifters and the GD... I need to tidy them up a bit (shorten brake lines particularly!)
it may be the lens distorting a little?
I'm afraid I preferred it before. The angles look better somehow. And a Gravity-dropper never improves aesthetics. Still, it's an interesting bike and no mistake. 🙂
Aesthetically I think I preferred it before - and that ain't saying much!
How does it ride though?
Indeed - despite the looks I wouldn't mind a play on it.
I'm not sure anything based around that particular frame is ever going to look particularily good.
Is the hammerscnidt/alfine system better/lighter/cheaper than a solo rohloff hub?
It sort of looks like you've taken something vital off it and not replaced it but I can't quite put my finger on it.
Hammerschmidt's are great though, if you're happy with a bit of weight and drag the instant shift is amazing.
rides fine, a little bit of noticeable drag in overdrive, but bearable (for now!).
will probably fit a shorter stem, I think it's a 90mm/10 degree thomson on there at the moment. I reckon a 50mm OS stem would be better!
I like Marmite. That is am not so sure about. The drivetrain is interesting, I like your thinking. But asthetically, no.
Transmission very good and interesting - everything else Nil Point. I'm not trying to case offence, but that does really look like a lash-up off ebay.
It looks better with the seat down, it's a street/jump/4X frame after all, so it's not meant to have a long seatpost exposed... I don't think that's helping things. Plus the tyres are a little skinny, 1.95 Trailrakers and the cable routing's a tad messy at the moment.
Don't think it's lighter, probably not 'better' either. I bought my hammerschmidt in the States, so much cheaper than here, and the alfine was off the classifieds. Drivetrain cost around £450 all in...
Are you sure you need the Hammerschmidt? The Alfine is like a 1x9 set up and for all my riding I find it fine.
Hence my nickname for it, the Frankenbike... made of lot's of mismatched bits 😆 I'll continue to work on it and who knows, I may make it look decent in the end 🙂
Probably not TBH, but it's a fun/interesting experiment... certainly different anyhow. I do find with a 1 x alfine setup that the hardest (highest?) gear is quite often not enough, so that's were the hammer is good to have, gives you a 36Tx24T ratio (I think)
The head angle looks super steep with the vans. Aren't those frames meant to be run with 140mm+ forks?
i think it needs a ghetto hammerite stealth black paintjob
Angles do look odd. Are the forks set to the full 5"?
I think your seat is angled too far forwards too.
Also, those skinny Panaracers are going to feel well out of their depth on a bike like that.
I won't even mention the stem. 😉
Why not leave the Hammerschmidt on and go for one cog one the back and use it as a jump bike that you can ride back up the hill. Then put the Alfine on a proper bike.
As far as I can tell, the frame is a prototype Miii, it's a 15" rather than the production 14". Orange reckons 100-130mm forks, though of course this frame could have a different HA to the production ones... should give Orange a call to check I guess!
That's under serious consideration...
not sure... they may be adjusted to 100mm, what's the way to check, just get the tape measure out?
Preferred it with the E150!
Your prototype looks quite different, especially around the headtube gusset and seat stays - the angles could be steepened by the slightly downhill patio though!
Your bottom bracket looks too low. It looks like a plastic bike that has been left too close to a fire and sagged in the middle. Sorry.
AND
sort your bars out!
What did you think of the E150?
[url= http://www.singletrackworld.com/forum/topic/specialized-forks ]Lifer, have a look at this recent thread on the E150[/url]
preferred it before. but think its a cool concept...
much better. I think it was the sloping patio that caused the problem 🙂
the silly skinny tyres weren't helping either 😆 looks much better with beefy 2.4 rubber 🙂
For me you need to get rid of the gravity dropper too and just run a normal QR collar. Surely a few heavy hits jumping and that gravity dropper will be a non functional heavy piece of trash?
And still too many cables 😆
I originally liked it, your gradually making it worse. It was unigue and hardcore before.
Surely it was 3 cables and 2 brake lines?
And I have a Kona Shred with Revs on as my only bike so i can kind of see the attraction in bikes like this. Mine has rigid forks on for commuting during the week and that makes it look marginally better in my opinion, but I wont be posting any pictures of it on here!!
I think the GD will be useful for 'undulating' trails, plus it's nice to not have to stop at the top of a hill to drop your saddle in preparation for the downhill and jumps to come 🙂
I certainly won't be subjecting the GD to any heavy landings when it's extended, that'd be a recipe for disaster, definitely! The remote is so handy and quick to use, so when you want to drop the saddle it's just done in a click, simples 8)
I may yet go back to the E150 fork up front... time will tell 🙂
exactamondo... now it has 2 cables and 2 brake lines 🙂
The frame is a prototype SubZero. You need 160mm forks on to make it work.
that's what it was sold to me as... but then I saw the Miii and came to the conclusion it was a prototype of that...
Are you certain of your statement, or just guessing (no disrespect intended 🙂 )?
cheers 🙂
Looks more like it to me too...
Loooooow BB height, even with 2.4" tyres fitted, VERY steep head angle (when fitted with your current forks), and long chainstays all compared to the Miii make me believe it too is most likely a prototype Sub Zero or similar.
If it were mine, would pop some coil lyriks on, put the Alfine back on, drop the Hammerschmidt and the Gravity Dropper, and go ride...
For those who may be interested (not that many I'm sure!), I've heard back from Orange and the frame is definitely a prototype 2007 Sub-zero, manufactured late 2006, so it's designed around a 130-150mm fork...
Dave at Orange reckons the downtube borrows a fair bit from the 224, so the E150 should be cool on it in the end, so that's what'll be going back on 8) Now to decide if I want gears or not 😆
The BB drop (below wheel axles) looks way too low with the fox van 125. It looks acceptable with the E150, similar to the pic of the production Miii
