Half-Link Chains
[Closed] Half-Link Chains
 nuke
[#3566353]
How do you tell when they are worn out? Is it the same principle as a normal chain and therefore I just use my chain wear indicator?
I put the chain wear indicator on and it's showing over 1.0% stretch but the chain is only about 2 months old.
Posted : 15/01/2012 10:06 am
I heard a anecdotal evidence that they do stretch more but that seems really quick.
I don't see why it would be difference from a normal chain though, the construction of the bits that wear is the same.
Was it onto an old setup? WOrn sprockets on a singlespeed would cause quick chainwear.
I don't normally check chain wear and just run them for about 12 months. Having said that the plates on mine snapped on Thursday and I had to limp home so maybe not the best advice.
I'd be interested in a proper answer.
Posted : 15/01/2012 10:41 am
I had one on my bmx. I used it for about 2 weeks and it stretched loads. I took a (half) link out and its been fine since.
Posted : 15/01/2012 10:46 am
 nuke
A little search around the internet suggests they do stretch more but then I always thought stretched = worn and therefore will need replacing.
[i]Was it onto an old setup? [/i]
Old setup but not that old. Being used with an Alfine
Posted : 15/01/2012 12:07 pm
