GXP crank into BB30...
[Closed] GXP crank into BB30 frame
[#9749929]
Bagged a cheap Eagle GX groupset with that eBay 20% deal over Christmas, but due to panic buying 10 mins before the voucher expired managed to end up with a GXP crankset rather than BB30.
A quick Google suggests there are adapters available. Can anyone recommend one which is a pain free long-term solution or would I be better off just sourcing another crankset? Ta!
Posted : 03/01/2018 1:03 pm
Get a praxis works adapter, far better than BB30, I put one on my stigmata (& a gxp crank) and it's been great
Posted : 04/01/2018 12:48 am
I've got some adapters for GXP to BB30 (Enduro ones). Happy to sell them if you're interested? I switched to some BB30 cranks so they're unused now. They were fine whilst I used them though.
Posted : 04/01/2018 6:21 am
I got fed up with my BB30 on my lefty and so converted it to 68/73mm threaded .
The adaptors creeked like hell
http://www.chainreactioncycles.com/fsa-bb30-threaded-adapter-b3119-/rp-prod129935
Had my bike rebuilt and gonna test ride it at the weekend
Mines an Xt crank Ht2 but you can get the gxp bb to fit 68/73
Posted : 04/01/2018 7:44 am
The first line on their web page is THIS IS NOT AN ADAPTER 🙂
sounds like it might be the easiest & least creaky solution though, ta!
thanks, I'll probably go down the Praxis route though if I can find one at a good price!
Posted : 04/01/2018 5:54 pm
Zilog6128 - You don't say what frame the bottom bracket is for so I'm not sure whether what I have will be useful to you but I recently bought a Specialized Epic which I wanted to run my Rotor Rex cranks on so bought a Praxis Works adapter. It turns out that the adapter is too short (shell is 73mm and the adapter is for 68mm shell*) so it's no good to me. It's practically brand new but as it was opened and fitted, I couldn't send it back. I even have some surplus Hope GXP bearing adapters to run GXP cranks on standard/Shimano style bearings which you're welcome to as well as I no longer have SRAM cranks on any of my bikes.
* In my defence, I was sold the adapter on the promise that it was for 68-73mm BB shells; I'm not a buffoon.
Posted : 04/01/2018 7:47 pm
Ive just this week put a FSA adaptor on my cannondale with bb30. It presses in with a smear of loctite and then you can use a conventional external BB. After reading on here I put the adaptor in the freezer and frame on radiator before I started. Went in quite easily with 2 flat steel plates and threaded bar.
Posted : 04/01/2018 8:26 pm
zilog6128 - they're in the spares box doing nothing. let me know if you change your mind
Posted : 04/01/2018 8:55 pm
It's a Cannondale Trigger so unfortunately 73mm like yours otherwise I'd have had the Praxis! Interestingly whilst double-checking in the manual, I saw that Cannondale make an official adapter for this purpose, it's bloody expensive though (more than the Praxis, plus you then have to supply a BB!)
Posted : 05/01/2018 1:38 pm
