GXP Bottom Bracket ...
[Closed] GXP Bottom Bracket Drive Side Bearing......
[#6751374]
So mine has decided to grumble - can I replace the bearing and what size is it?
If not, is there anyone makes a reliable GXP B/B as this one is less than 12 months old and I only get out once a week if I'm lucky?
Posted : 05/01/2015 6:06 pm
The standard answer is get a hope BB and the adapter. GXP bb's are notoriously bad at running out, I used an O rubber ring round the axle to keep the top hat hard up against the bearing.
Posted : 05/01/2015 6:08 pm
PF30/BB30?
Posted : 05/01/2015 6:09 pm
 Del
the OP said GXP so I'd guess not.
there are some good deals around on SLX cranksets at the mo OP...
Posted : 05/01/2015 6:22 pm
I have successfully changed both bearings in a GXP BB for Enduro ones. The NDS one is a bit of a special one but the drive side is off the shelf. You may need to prize out a spring clip before pressing them out. Depends on your BB
I have seen 2 different internal diameter bearings used too so you need to be careful. On one BB the bearing was a direct fit on the axle of the cranks. On another the bearing was 1mm larger than the axle and had a thin plastic top-hat which went into it before the axle did and helped with sealing.
Posted : 05/01/2015 7:08 pm
GXP Team is £20, may as well replace the lot than faff with replacing one bearing.
Personally my GXPs last a good couple of years.
Tips...
Put an o-ring on the drive side in the gap between the dust cap and crank. That will stop the cap drifting out and letting crud in.
Tighten the crank nut to the torque specified. It's a huge amount, and a lot of issues are down to people just doing up by hand thinking it's enough torque.
Don't pressure wash the BB.
Posted : 05/01/2015 7:35 pm
Quite impressed by the Uber GXP I received today (admittedly I've not used it yet!) - the bearings are standard 6805s and the top cap has a return on the outer diameter of its inner face such that it sleeves back over the outer race of the bearing (does that make any sense lol?!!). I intend to pack it with marine grease which should give the best seal of any external bottom bracket I've seen.
Posted : 05/01/2015 9:11 pm
Like this:
[URL= http://i48.photobucket.com/albums/f241/Dave_H34/20150105_201659_zpsnyk9nuie.jp g" target="_blank">http://i48.photobucket.com/albums/f241/Dave_H34/20150105_201659_zpsnyk9nuie.jp g"/> [/IMG][/URL]
Posted : 05/01/2015 9:26 pm
Thanks all!
I have a wavey washer on the drive side so should keep the dust cap in place. I shall consider my options after your advice!
Posted : 06/01/2015 9:49 am
 gren
deadkenny - Member
Mine's starting to click after just over 2 years and just bought another to replace it. Like DK says, at £20 for 2 years it's just easier to replace.
Posted : 06/01/2015 9:54 am
Give it a service, GXPs can be part stripped and cleaned up.
http://www.stickboybike.com/2013/04/getting-most-out-of-your-sram-gxp.html#!/2013/04/getting-most-out-of-your-sram-gxp.html
Andy
Posted : 06/01/2015 11:07 am
Token do one as well I think. TBH I don't see the sense in buying an expensive BB to fix the GXP issue, unless they're really nice cranks it's probably better to replace them entirely.
Posted : 06/01/2015 11:40 am
What is the difference between a GXP BB and a BB30 BB? Thinking about getting some SRAM XX1 cranks, but I don't know if they'll go into the BB I've currently got.
Posted : 06/01/2015 12:26 pm
GXP is threaded, BB30 press fit
Posted : 06/01/2015 1:27 pm
Like daveh, I've got the Uberbike GXP version on my winter bike which is out in all weathers. No probelsm at all with it and I'd recommend it. Different colours available too 😛
Posted : 06/01/2015 1:51 pm
