Guy Martin proper c...
[Closed] Guy Martin proper cleaners and knackered squirters.
[#11982531]
I've had 3 squirters now that have been gummed up by Guy Martin's cleaner, specifically I think the degreaser. The first one was an old Muc-off one, so I assumed I was just unlucky but it's done for a Guy Martin and another Muc-off one since.
Am I just unlucky or is this a thing? I'm wondering if it's the dissolvable pouch that's gluing up the piston in the trigger.
Posted : 31/07/2021 6:19 pm
 lc87
I’ve had it where it’s gummed up after infrequent use. Found sticking it under the hot tap and working it til it sprays out does the trick
Posted : 31/07/2021 6:23 pm
Tried that. It got the lever moving again but wouldn't produce any pressure/spray. This was with one of the Muc-off and the Guy Martin one. Think I might have damaged them squeezing too hard with them bunged up.
Posted : 31/07/2021 8:09 pm
Yup it seems to be the pouch that gums things up, noticed this the other day,
Posted : 31/07/2021 9:20 pm
I've not had it with the cleaner, not tried the degreaser. I did think the bottle it came with was a bit rubbish and had too much a direct spray where I wanted a bit more of a mist spray.
Posted : 01/08/2021 10:30 am
I've also had the same problem so will try soaking the head for a while, thanks for the tip.
On a related note how are you finding them? I love the idea but the cleaner only seems ok-ish and the degreaser appeared to be hopeless. I'm open to it being user error though, do you need to let it soak longer or something?
Posted : 01/08/2021 10:46 am
 lc87
Only used the cleaner, but agree with the above. Would be much better if the spray was more of a mist than a jet, easy to miss what you’re trying to cover. Not sure how much better any of these cleaners actually are than warm water really. Smells nice though!
Posted : 01/08/2021 10:57 am
I find both quite decent, put the degreaser on first and scrub it in to work while doing the rest of the bike. I like the idea of only transporting the powder and not half a kilo of water too, (not sure the rest of Mr Martin's lifestyle supports these green credentials though 🤣)
I'm going to get a couple of new bottles and tip the power out of the wrapper in future.
Posted : 01/08/2021 11:47 am
