Gummi Pfledge... Do...
[Closed] Gummi Pfledge... Does it make your doors creak?
[#9355636]
Hiya Chaps,
I got some Gummi Pfledge, as recommended on forums, as I had a slightly creaking rear passenger door seal.
After applying it the seals are incredibly creaky. I washed it off with IPA, and they're back to not being creaky.
I thought this stuff was supported to be magic on door seals. Anyone else had similar issues?
Ricks
Posted : 30/05/2017 7:40 pm
I can't say I've ever noticed it cause issues and i've used it on loads of cars over the years. How old and worn are the seals?
Posted : 30/05/2017 8:07 pm
Works fine on my cars - no squeaks
Posted : 30/05/2017 8:21 pm
Damn. Car is only just over 10k and 2 years. It's a BMW 320, the seals look pretty new, as soon as I put the Gummi Pfledge on you can hear the doors moving over bumps, as the seals move a very tiny amount. It's rubber on metal that's moving
Posted : 30/05/2017 8:54 pm
It's the Sonax Gummi Pfledger stuff I'm using....
Posted : 30/05/2017 8:55 pm
 burt
Didn't do anything for me so tried a very thin layer of vasaline. Works a treat. Mine was a BMW too.
Posted : 30/05/2017 9:01 pm
BMW repair instructions for creaky door seals are to clean and drive, if it's no better there is a rubber seal care spray, can find out part no for you if you want?
Posted : 31/05/2017 12:03 pm
Take the BMW back to the dealer. There is an approved fix which puts black tape in the aperture. You can't see it with the door closed. Its a warranty job under 2 years.
Mine (14 plate) did the same thing. Now quiet.
Posted : 31/05/2017 1:17 pm
Cheers everyone. I think I've found the problem, and the fix.
The teflon tape would have solved the problem too.
I washed the car with a shampoo and wax mix, which got onto the seals. That started the creaking.
Then applying Gummi pfledge on too, without cleaning the wax off, made it worse. I didn't realise the seals were compromised already, and they'd been cleaned only a couple of weeks before.
So, I IPAed all the seals, many times, then applied Gummi again.
No creaks.
Stupid selection of materials on BMWs.
Posted : 01/06/2017 10:32 pm
