Guitar Amp help ple...
[Closed] Guitar Amp help please
[#1156651]
My son got his VOX VT100 but we can't get a sound out of it, I've no idea. Can anyone help with a walk through.
HAPPY CHRISTMAS
Posted : 25/12/2009 10:03 am
RTFM oldgit! 😉
Merry Christmas
SB
Checks -> -> ->
The led comes on to show that the amp has power.
Turn it up full volume. Is there any hissing at all coming out of the speakers?
Writing some more while U check
Posted : 25/12/2009 10:06 am
More checks -> ->
Just plug the lead in with no guitar on it. Touch the end of the cable. This should give some crackling (there's no current to harm you). It'll tell you thet the amp is working, but there's no output from the guitar.
Is it an open back amp? Has one of the speaker connections come off?
Posted : 25/12/2009 10:18 am
Is he plugging straight in or using the effects loop?
Take any effects out of the chain. Try just the guit straight into the Amp.
Your lad must be gutted......
Mail me your telephone number and I'll give you a call if you like....
stratobiker@yahoo.co.uk
SB
Posted : 25/12/2009 10:23 am
Turn it off. Unplug it. Strat again..... ACTUALLY PHYSICALLY UNPLUG FROM POWER.
Like the guys did here.......
http://www.voxamps.com/forum/topic.php?id=680
Posted : 25/12/2009 10:29 am
Thanks for your help.
We can get a tiny sound with everything wound right up full?
Posted : 25/12/2009 10:38 am
Can you try it through headphones?
That'll show if the pre-amp is working.
From the thread.......
If it works on headphones then the problem is with the speaker/speaker connections.
If it's working on H/Ps then the pre-amp section is okay. The problem could still be in the power amp section that has the tube, but it is worth checking the speaker first. Check to see if the speaker wires have come adrift. If it all looks okay than it's worth checking that the speaker is not open circuit. Disconnect the speaker and use an ohm meter on it to see if there is continuity through the speaker.
SB
Posted : 25/12/2009 10:45 am
Getting some sound through the H/Ps not massive. All wire to the speakers are connected.
Yeah he is gutted that was a lot of part time work for a 12/13 year old.
The box had been opened?
Posted : 25/12/2009 11:06 am
Pardon me if I point out the glaringly obvious, but have you turned the gain up as well as the master volume?
Posted : 25/12/2009 11:41 am
Yes everything on full and you can just about hear something coming out of the speakers.
Posted : 25/12/2009 11:46 am
oldgit, there should be a separate control knob for the output section of the power amp - on my older 50w Vox modelling amp it's on the back panel, near the headphone socket - Try turning it up a bit, post back if no luck.
Happy Christmas everyone!
Posted : 25/12/2009 11:49 am
erm, you do have the volume up on the guitar don't you?
Posted : 25/12/2009 1:02 pm
I assume I'm entitled to a replacement or full refund?
Posted : 25/12/2009 1:07 pm
oldgit, yeah, course you are.
Just try a different lead first though.............
Posted : 25/12/2009 1:12 pm
its got valves no? does it make an almighty clatter if you rock it back n forth? (not that you're meant to do that)
Posted : 25/12/2009 1:17 pm
Bummer! 🙁
Just got back from my bike ride.
I was hoping I'd read that you'd got it sorted.
Are you sure that the guitar and lead are working?
Is there some way of testing them. Has your lad got an old amp or something?
Are you still trying, or are you resolved to taking it back?
Whichever, please let us know the outcome.
SB 🙂
Posted : 25/12/2009 1:20 pm
No everything works on his practice amp, we have tried different leads and the guitar is a Jackson KVX10.
With everything ramped up i.e Power/gain/master/volume etc etc we just get a tiny sound we do get more through the headphones.
Posted : 25/12/2009 1:34 pm
OK, try this if you haven't:
"Restoring the factory settings
Here’s how to restore all settings of the VT-series to their factory-set state.
NOTE: This operation will erase all programs that had been saved to channels,
and will initialize the factory-set programs.
NOTE: This will also initialize the effect and noise reduction settings that you
made in Manual mode.
1. Turn off the power.
2. While holding down the [CH1] and [CH4] switches, turn on the power. When the
BANK and CHANNEL LEDs start blinking, release the two switches you had been
holding down.
HINT: If you decide to cancel initialization at this point, press the [TAP] switch.
3. Press the [BYPASS] switch. The BANK and CHANNEL LEDs will change from blinking
to lit, and initialization will begin. In one or two seconds, initialization will be
completed, and you will switch to Preset mode.
NOTE: Never turn off the power while initialization is in progress."
Also, check and see if it's on noise reduction mode, if it is turn that off. I don't think it's the power level on the back panel but it wouldn't hurt to check, spin it up to halfway. Lastly, as far as I know that model doesn't have a tuner but if it does, switch it off.
There's a troubleshooting guide in the manual, among other things it says to make sure there's nothing jacked into the external speaker output, headphone output, or pedal loops.
Not sure if any of these will help but it can't hurt. Good luck, hope you get it sorted! Vox make good amps so don't worry that it's a bad purchase, it might be that there's something wrong but don't be put off!
Posted : 25/12/2009 1:45 pm
Nice one Northwind.....
Fingers crossed.
SB
Posted : 25/12/2009 1:49 pm
I'm sayin' nowt
Plum
Posted : 26/12/2009 4:10 am
