Guide/Magura Q. sor...
[Closed] Guide/Magura Q. sorry.
[#9599508]
I currently have Sram guide brakes with hidden hoses and want to swap the calipers and levers to Magura. Can I leave the hoses in the frame and just attach the new ones or will I need to feed the new hoses through the frame? Is there a compatibility issues between the different fluids Sram & Mature use or is there a negative 're rotting seals etc..
Posted : 10/10/2017 2:44 pm
Edit..
Posted : 10/10/2017 2:45 pm
Oils are incompatable as would be the fittings at each end I'd imagine.
I just tape the end of the new hose to the end of the old one as I pull the old one out - pulls new one through and if you use decent tape no fluid leaks.
Posted : 10/10/2017 2:48 pm
