GRX RX600 double ch...
GRX RX600 double chainset, ok for 11sp?
[#12804633]
I bought a Shimano GRX 600 double chainset from Ribble that was advertised as 11sp.
However the chainrings are etched 10sp. Will it work with my 11sp chain?
Thanks
Ian
Posted : 27/04/2023 10:26 pm
600 is 11 spd, 400 is 10spd.
What’s the part no around the pedal boss?
Posted : 27/04/2023 10:43 pm
Qh ok....i ahall go and check....brb
Ian
Posted : 27/04/2023 10:50 pm
Ok it says its an rx600 but the rings are definately etched 10sp.
So im guessing its a hybrid with non original chainrings?
Ian
Posted : 27/04/2023 11:04 pm
Shimano's GRX website shows 10 speed and 11speed GRX600 - FC-RX600-10 and FC-RX600-11.
Posted : 27/04/2023 11:05 pm
It should work because the internal dimensions of the chain are the same.
The external width of the chain is slightly narrower on 11-speed, about 0.5mm less, so barely noticeable. If you're not happy return it, but if it's bargainous...
Posted : 28/04/2023 7:28 am
It will be fine. 10 speed cranks work fine with 11 speed chains but not the other way around, I assume you have a GRX front mech as well?
Posted : 28/04/2023 7:50 am
I'm running an old 10 speed ultegra chainset with 11 speed everything else, works great.
Posted : 28/04/2023 8:19 am
Shimano’s GRX website shows 10 speed and 11speed GRX600 – FC-RX600-10 and FC-RX600-11.
So it does, and the 400 version has gone. Odd!
Posted : 28/04/2023 8:58 am
My mistake - 400 series has always run 600 cranks with 10 spd rings.
OP - wouldn’t worry - 11spd rings would likely shift more crisply, but expect your set up will still shift better than most alternatives!
Posted : 28/04/2023 9:47 am
I have a grx fr mech and this item cost me £30 new, so i will keep it!
Thanks for the input about chain internal width!
Regards
Ian
Posted : 28/04/2023 10:18 am
