Grrr...stubborn for...
[Closed] Grrr...stubborn fork oil seals
[#6242701]
I'm currently servicing a set of Pikes and no matter what I do, I cannot seem to persuade the oil (lower) seals to part company with the fork lowers.
I've tried using a screwdriver wrapped in tape, tyre levers and an expulsion of expletives but nothing seems to make them budge a chuffing bit, the best I can do is to tear a small piece of the seal away but the rest stays put.
Any tips?
Posted : 03/06/2014 1:20 pm
 LoCo
19 or 20mm open end spanner, rag on top of fork to lever against, and work you way round the seal
Posted : 03/06/2014 1:28 pm
What LoCo says, not that he needs my approval!
Posted : 03/06/2014 1:43 pm
And if you've got mechanical sympathy, grit your teeth and wince. Did my Lyriks and it takes more effort than you want to use.
I left my old dust seals in to protect the tops of the forks when levering (til the oil seal 'gives', obviously).
Posted : 03/06/2014 1:46 pm
Thanks all, I'll give that a bash.
Posted : 03/06/2014 2:51 pm
Downhill tyre lever.
Posted : 03/06/2014 4:13 pm
