grips wont stick
[Closed] grips wont stick
[#1252907]
i removed my grips the other day and have tried to refit them but they won't stick using hairspay for some reason,any ideas why?
Posted : 23/01/2010 9:02 pm
 jedi
gone baggy
is there any way they'll stick again then as i'm riding in the morn?
Posted : 23/01/2010 9:04 pm
 jedi
glue.
Posted : 23/01/2010 9:11 pm
Superglue or paint.
Posted : 23/01/2010 9:13 pm
Wot Jedi said.
Artists spray mount is the solvent abuse of choice for me.
And you can always tie the ends with tire-wire. Ever wondered what those grooves were for?
Posted : 23/01/2010 9:14 pm
...or some of [url= ]these[/url]?
Once you've tried 'em you won't go back... 🙂
Posted : 23/01/2010 9:15 pm
Bit of petrol out the lawnmower might do the trick. Or meths. Evaporates real quick and leaves no trace of anything to make them slip.
Posted : 23/01/2010 9:17 pm
Tried GT85?
Seriously - it does work!
+1 GT85 Stripe aint joking
Posted : 23/01/2010 11:47 pm
 jedi
it dont work when the grips go baggy
Posted : 23/01/2010 11:49 pm
c9tin never said they were baggy only that hairspray did not work which oftern it does not
Posted : 23/01/2010 11:55 pm
i always use disc brake cleaner to remove and replace my grips. works everytime..
Posted : 24/01/2010 1:02 am
thanks for the replies.i've managed to sort it,i took them off again,wrapped masking tape around the bars,then put golf grip double sided tape on followed by a bit of white spirit and they seem rock solid now(hopefully).
Posted : 24/01/2010 9:25 am
Put some Grip Fil on the
Posted : 24/01/2010 10:14 am
[i] gonetothehills - Member
...or some of these?
Once you've tried 'em you won't go back... [/i]
I did... 🙂
Posted : 24/01/2010 12:27 pm
AndyP - Member
I did...
Me too.
Posted : 24/01/2010 12:38 pm
get lock on grips 🙂
Posted : 24/01/2010 12:39 pm
I always ended up stretching the grips when removing.
Also found Fairy liquid helps them back on and dries like superglu.
Gone for lock on's after destroying too many grips when chnaging bits.
Think shimano has a new clamp on shifters soon so you don't need to remove grips anymore to swap gear levers-yay!
Posted : 24/01/2010 12:41 pm
lock-ons all the way!!
Posted : 24/01/2010 12:47 pm
