Greasing Pedals &am...
[Closed] Greasing Pedals & Bearings
[#7073607]
I've got a very worn pair of SS Nano Techs I would like to overhaul.
Is there a tool/adapter that you can screw in to inject grease?
Are the bearings replaceable? Where do you get the 9mm (guessing @ 9mm) very thin walled socket from?
Posted : 18/05/2015 12:56 pm
 maxb
BITD when the first M737 SPDs arrived and the plastic collars invariably stripped we used to just drill a 1.5mm hole in the outside of the body and inject grease in that way forcing out the old grease.
Posted : 18/05/2015 1:13 pm
I can get the grease in, I was wondering if someone had come up with an easier way than removing plug, fill plug with grease screw on, repeat 100 times.
Posted : 18/05/2015 3:49 pm
 maxb
Errrrr.......drill a hole in the plug?!
Posted : 18/05/2015 5:20 pm
