Grease to press in ...
[Closed] Grease to press in my BB bearings?
[#9642125]
I have a Trek Elite carbon HT. Having drifted the BB bearings out of the aluminium bb shell, do i grease the new ones prior to installation?
Posted : 02/11/2017 2:34 pm
I would.
Posted : 02/11/2017 2:43 pm
Yep. If it’s an Alu Shell then use what you like. No harm using carbon specific grease if that’s what you have, and possibly good if it gets trapped against carbon surfaces.
Posted : 02/11/2017 2:48 pm
The bearings sit in an aluminium shell that is pressed/bonded into the carbon frame.
Thanks guys...i will lightly grease. Its what i though, but then i had a moments doubt...damn old age! 🙂
Posted : 02/11/2017 2:51 pm
Yup, I use a thin smear of lithium grease when refitting BB bearings (actually, pretty much any bearings), nominally to reduce creaking, but really to make sure they'll come out again next time 🙂
Posted : 02/11/2017 2:53 pm
don't mean to hijack ... but will anyway 🙂
with pressed in bearings, when is grease appropriate and when should a retaining compound (threadlock type stuff) be used? Does it just depend on the application and materials?
I ask as I've been looking into this and opinion seems varied on the correct stuff to use
Posted : 02/11/2017 2:57 pm
Personally, I don't ever, ever threadlock bearings...unless I need to 🙂
What this means, is that if I get creaking cranks from a BB30 then I'll grease it up and if that doesn't work, it'll get its ass threadlocked into the shell. Whatever it takes!
Posted : 02/11/2017 4:37 pm
