Gravity dropper tur...
[Closed] Gravity dropper turbo service
[#4366125]
So I have changed the cable inner and outer on my gravity dropper turbo for the first time. On putting it back together it's now putting stuck in the up position and does not respond to the lever, despite the lever pulling the cable ok when it's in bits. Anyone know how to fix this? Thanks
Posted : 15/09/2012 9:49 pm
Have you tried:
1) Adjsting the collar a bit. Moves the pin up and down minutely.
2) Very slightly loosening the two screws that hold the pin housing on. I used to find if they were too tight it stuck.
Posted : 15/09/2012 9:55 pm
Ok cheers will try that tmrw
Posted : 15/09/2012 11:03 pm
