Gravity dropper tur...
[Closed] Gravity dropper turbo
[#7800010]
Anyone have one of these? The post moves fine from middle to high, but will not lock in the lowest setting. I have taken it apart and without the spring it locks at each position.
Posted : 30/04/2016 6:52 am
I can't remember the specifics, but you've probably got the lower collar screwed down too tight. If its hand tight, its probably too tight. If its too loose, there will be a noticeable amount of up/down play when you sit on the saddle.
Posted : 30/04/2016 7:21 am
Have you checked the rubber boot is sitting in the wee groove just below the seat camp?
Posted : 30/04/2016 7:27 am
Just play with the collar, mine loosens over time, quick twist and it engages again
Posted : 30/04/2016 7:28 am
Boot is off at the moment.
Changing the collar tighteness has no effect, what does this do? Is it a stop against the inner post?
I think my problem is with the spring how do you know how much to tighten the bottom bolt / spring?
Posted : 30/04/2016 7:38 am
I loosened the spring right back...
Posted : 30/04/2016 7:44 am
So how far up is the bottom bolt on your post?
Posted : 30/04/2016 7:45 am
It sounds like the disc in the bottom of the post is too high up so there isn't space for the spring to compress down low enough. I had that when I changed the main post on mine (because I changed frame seat tube diameter) - it needed to be almost flush with the end of the main tube.
Posted : 30/04/2016 8:57 am
That's it! Had the disc way to high
Posted : 30/04/2016 9:09 am
Posted : 30/04/2016 9:29 am
