Gravel/Adventure Fr...
[Closed] Gravel/Adventure Frame Question
 robh
[#9539667]
Is there such a thing as a canti/v brake gravel frame, looking for something a but more comfortable than my current racy Kenisis cross light for gentle off road stuff, have nice wheels and group set so didn't want to go disc, although like the look of the Space Chicken.
Posted : 09/09/2017 11:56 am
seems a bit unlikely seeing as the whole 'gravel' trend thing is post-disc but you might find some less aggressive canti-brake cyclocross frames - which for your stated purpose would be ok I would imagine.
What's the issue with the crosslight frame though? Is it the short headtube? If so then a shorter stem with more rise could change your riding position to be more upright, if that's what you're after. I had a Pro5 and ran my stem in the up position just to lift the bars a bit as the kinesis frames have quite a head-down sort of geometry. Later changed to the Pro6 disc in a larger size to get a bit more upright.
Posted : 09/09/2017 9:34 pm
Kona Jake - oldish ones are cheap S Hand
Posted : 09/09/2017 9:37 pm
 robh
Cross light low and long and just find it a little harsh, going to try some shallower bars and a shorter more upright stem, but just wondering if there were other frames to consider.
Posted : 10/09/2017 7:43 am
 aP
An older Dawes Galaxy with racks and mudguards removed would probably do what you want.
You could always get it resonated with a fashionable paint job and no one would know.
Posted : 10/09/2017 7:55 am
Focus Mares, if you can find one someone wants to sell.
I've been looking for some time now, but all the canti bikes are so good the owners don't want to sell them..
Posted : 10/09/2017 7:57 am
Dare I suggest a Pompino?
Perfectly good on gravel roads.
Put a decent set of wheels on, a carbon fork and you're good to go.
The Dawes Galaxy is a good suggestion - nice quality steel, a well proven design and well worth a repaint (it will be hard to find one that hasn't done tens of thousands of miles).
Posted : 10/09/2017 8:21 am
Yes I'd look at your riding position and tyres first. They'll have more influence than Frame material. Try a shorter, shallower and wider bar too, it'll help move your weight off your hands a bit.
Posted : 10/09/2017 8:35 am
 Jerm
I have an All City Macho Man which probably matches your requirements. Heavy fork though.
Posted : 10/09/2017 1:47 pm
Touring bike?
Posted : 10/09/2017 4:59 pm
 robh
Cheers for the advice all, going to play around with stems and bars to see if it helps.
Posted : 10/09/2017 9:20 pm
 Bez
Cross Check seems the obvious nomination. Fork is pretty flexible (at least it is with my weight on it) which is, aside from wider tyres, what you want for comfort.
Posted : 10/09/2017 10:52 pm
Amazed no one has mentioned the [url= http://www.pashley.co.uk/bikes/bicycles/pathfinder-trail.php ]Pashleys[/url] made in Britain.
These are the sort of bikes you would have been out on the mountains on before the mtb was invented.
This one with discs and an Alfine has all bases covered IMO - good enough to do the likes of the Corrieyairack.
Being a retro model myself, I'd prefer the Clubman and put cx tyres on it. A 3 speed S-A hub is the essence of simplicity. One speed for the mountains, one for the road, and one for downhill and tailwinds. What more could you want? 🙂
Posted : 16/09/2017 8:05 am
..and thank heavens they were 🙂
not my cup of tea but i can appreciate the vintage look.
Posted : 16/09/2017 8:24 am
Too late for Edit.
Pashley also do the above with those dangly gear changing devices called derailleurs - you can get full Campag if you want.
There's also a left field gravel bike. The Guv'nor or Speed 5. It's made from 531, so good quality and you could stick a substantial grippy tyre in there.
Before you dismiss them, bear in mind the original design and shape of that bike was the design used when all bikes were "gravel bikes". Intrepid folk did trans-continental rides on no roads in Australia and USA with more or less that design.
I'd be tempted to replace the Westwood rims eventually. Although they are not as rigid as a modern double wall they are gentler on the tubes if you rim strike and they are easy to straighten. I know that from having done thousands of miles on them on rough surfaces and ridden them harshly in my impetuous youth.
BTW does anyone know if Pashley sell framesets?
Posted : 16/09/2017 8:32 am
OP I had the same question as you. If you're genuinely looking for a lightweight gravel bike (i.e. a bit less racey than a CX bike but less tourer-y than a tourer) that takes cantis, then something custom, or a Van Nicholas Amazon?
Scotroutes on here has one, I took a look but couldn't afford. Think it weighs 2kg-ish with fork but website isn't entirely clear on that point.
Maybe a future bike for me...
Posted : 16/09/2017 9:10 am
Older Spesh Tricross?
Galaxy would be nicer. Late 80's, early 1990s are a good vintage and often a bargain.
Posted : 16/09/2017 10:00 am
[quote=13thfloormonk ]OP I had the same question as you. If you're genuinely looking for a lightweight gravel bike (i.e. a bit less racey than a CX bike but less tourer-y than a tourer) that takes cantis, then something custom, or a Van Nicholas Amazon?
I do indeed have an Amazon - though I run mine with disks. I've no idea what the frame weighs either 😀
OP - a lot of the gravel/adventure market is using/specifying wider tyres. That's where disks open up so many more options as you're not then having to think about caliper/tyre clearance.
Posted : 16/09/2017 10:05 am
Although for what it's worth, a set of mini-vs will clear a 40c tyre with guards..
Posted : 16/09/2017 10:25 am
Surly Cross Check
Posted : 16/09/2017 10:27 am
Had a thread a few months ago about this and revamping a Dawes Galaxy from the 90's, seem to have deleted most of pics bar this one:
[url= https://farm5.staticflickr.com/4355/36443241783_e400ef3b74_z.jp g" target="_blank">https://farm5.staticflickr.com/4355/36443241783_e400ef3b74_z.jp g"/> [/img][/url]
WTB Nano 40's fitted fine
Posted : 16/09/2017 11:27 am
13thfloormonk - Member
Yeah, I was more thinking about 650mm rims and 47mm tyres. I've not gone down that route yet but I should have an old set of Hope XC hubs that could repurposed once I get my loaner bike back from MoseyMTB.
Posted : 16/09/2017 11:40 am
scotroutes - Member
I reckon some of the older 27"/700c tourers with plenty clearance for mudguards could easily handle a 650b rim and 50mm tyres.
That would be a game changer.
Posted : 16/09/2017 1:07 pm
[quote=epicyclo ]
scotroutes - Member
Would the brake pads line up with the rims though? I'm guessing there would be some options available.
Posted : 16/09/2017 1:08 pm
scotroutes - Member
Good point. I tend to think of drum brakes, so hadn't considered that. I can think of a few ways to do a bodge conversion to make the brakes fit, but ideally you'd re-braze the canti mounts or make an alternative mount.
Posted : 16/09/2017 3:58 pm
Either all city macho man, or if you really want to treat yourself pop into rourkes and get one built to suit 😀
Posted : 16/09/2017 5:34 pm
