Gravel- swapping 70...
[Closed] Gravel- swapping 700c for 650b
[#9534052]
Currently using 700x 38c schwalbes, if I want more cushion and put 650b wheels and some xc tyres on, say 2.0- will the BB height be about the same? They'll fit in the frame (Saracen Hack) but would have to sort something with the mudguards.
Posted : 06/09/2017 9:57 am
might drop a cm or 2, depends on the tyres
http://ridinggravel.com/components/wheel-comparison-650b-vs-700c/
Posted : 06/09/2017 10:06 am
So what you're saying is you want to ride a mountain bike from the mid 90's, only with drop bars?
Posted : 06/09/2017 10:11 am
700 = 622+2x38=698
650 = 584+2x50=684
difference is 14mm so bb would be 7 mm lower in theory.
My mate has swpped from 700x 35 to 650x 35 on his gravel bike to remove toe overlap. BB drop hasn't been a problem.
Posted : 06/09/2017 10:23 am
 aP
I ride my Bokeh with either 650b/ 2.1" Thunder Burts or 38mm Compass Loup Loup Pass. The pedals seem disturbingly close to the ground with the 38mm tyres on, but I've only had 2 pedal strikes in about 2500km of riding (which includes Gavel Dash, Paris-Roubaix, Exmouth Exodus and loads of riding in and around the Surrey Hills. I might be tempted to go up to about 43/45mm tyres for road riding once I've worn out the 38s.
Posted : 06/09/2017 10:37 am
650 x 42c is the same as 700 x 23, so if you don't end up using mtb tyres and fit gravel ones you'll drop your BB a bit. But unless you have a really low BB in the first place I can't see it being a problem at all. That bike is prob around 70mm bb drop?
Posted : 06/09/2017 10:39 am
Bit of bb drop is fine, just wondering really. That linked article quite interesting thanks. I might just try a bigger 700c or get second set of cheap wheels.
Posted : 06/09/2017 11:55 am
I could be wrong, but I think he's saying he is thinking of swapping 700c wheels for 650b
Posted : 06/09/2017 11:58 am
just checked, bb drop on my 650b slate is 650mm. Given that gravel frames are thought to have a lower BB height for stability it might not be a bad thing at all.
But, the reality is that it will make bugger all difference as a suspect a lot of what is written about gravel v cx is markety bollocks. plus taking a single dimension in isolation is a bit pointless.
if you are looking at a decent cheap set of 650b wheels, superstar are selling off stans mk2 crest rims on fuel hubs for £209. If they fire out a site wide discount code (which they usually do) you might get them for 10-20% less
http://www.superstarcomponents.com/en/stans-fuel-blowout-sale-wheelset.htm
Posted : 06/09/2017 12:19 pm
The drop will be a bit more than the difference in wheel radius because the bigger tyre will squish more.
Posted : 06/09/2017 3:39 pm
Jonnyboi, cheers for that I rate stand rims so have bought a set of those.
Now to decide what tyres...
Posted : 06/09/2017 5:01 pm
You can get 42c in a Saracen Hack frame - no clearance for guards though
Posted : 06/09/2017 5:14 pm
WTB resolutes, with tan sidewalls FTW.
I got mine from bike24 but see that chain reaction havevthem back in stock
Posted : 06/09/2017 6:35 pm
Been toying with the idea myself on a Genesis CdA. Currently running WTB Nano 40c and it looks like there's still some room for more (possibly up to 42C).
I also have a spare set of 650b Hope wheels (Tech Enduro). These are 23mm internal, so I'm wondering if they'd fit with the Resolutes?
Posted : 06/09/2017 6:50 pm
Mine are on stans crest mk3 which are the same width
Posted : 06/09/2017 7:09 pm
Cheers jonnyboi, pretty much sold it for me.
Think I'll order a couple of Resolutes soon then. I didn't really want to sell the Hopes 🙂
Posted : 06/09/2017 7:16 pm
Ive just built a tripster with 650 wheels and went for terene Elwoods in the light version.
They were cheap from planet x
And so far have been excellent for both gravel and 100+ road ride
They are 47mm
Posted : 06/09/2017 8:21 pm
Guards are staying on. Cant commute without some tarmac, Schwalbe G one bites look good but not available yet. WTB Nanos maybe but will need to be tubeless. How do the resolutes roll/last on road?
Posted : 06/09/2017 8:23 pm
Schwalbe G one bites.
Bites? Speed? Evo?
You can get a 650b x 38 G-One evo tubeless. Great tyre
Posted : 06/09/2017 9:15 pm
[url= https://www.schwalbe.com/gb/tour-reader/schwalbe-g-one-bite.html ]https://www.schwalbe.com/gb/tour-reader/schwalbe-g-one-bite.html[/url]
2018 tyre so cant find it for sale yet.
Posted : 06/09/2017 9:29 pm
Ahh, that's a new one on me. Looks superficially like a g-one evo with some of the lugs removed 🙂
Posted : 06/09/2017 9:44 pm
That g one bite in 650b is huge 2.1/54c. Can you fit that one a hack?
Posted : 06/09/2017 9:49 pm
Probably not, most likely will be too close to the chainstays never mind the mudguards.
Posted : 07/09/2017 11:30 am
