Hi All
In the market for a set of 700c gravel wheel.
Max Budget £330.
Currently looking at Hunt 4 season, and DCR Vivaldi disc wheelset. (both more or less in my budget)
Any other options I should consider, and has any one had experience with either the Hunt or DCR's
Many Thanks
My Hunt 4 Seasons have been fantastic. Light but very strong. Zero problems
Have had a pair of 4 Season Gravels for a couple of years - been spot on, still as true as when they were fitted (despite plenty of SDW clatterings).
Recently nabbed a pair of ‘nearly new’ X-Wide versions, also nice. Would recommend.
How heavy are you and how big a tyre are you looking to run?
I’d be looking at Hope 20FIVE
I am 75kg's and would run 35-45 tyres (tubeless)
I do occasional tour on the bike, so max all up weight would be 90kgs
Got the rear one of these to replace an old aileron rim on a hope hub during lockdown when local bike shops were shut. The rim badly dinged second ride and I’m looking at getting a new aileron rim, seriously under-impressed with it
What front/rear spacing and axle sizes do you need compatibility for?
I got the regular hunt 4 season as the gravel version wasn’t in stock and there only seemed to be a 1mm difference. No complaints so far. I’ve blatted then through loads of rocks and they are still running true.
these are for standard "non boost" QR wheels
Watches thread with interest.......
I've lost out on a couple of ebay deals recently for wheels, also after standard QR wheels for the Arkose.
some good stuff comes up on FB market place from time to time, but I am keen to buy new.
got two sets of DCR road wheels here, both great, one QR pimpy with Tune Hubs, AL33 rims one boost/through axle effectively a Vivaldi set with a different rim and just about to order another set for gravel use 45-50mm tyres so as per second set with wider 25mm rim
I'm running the Hunt 4 seasons wheels on my gravel bike. Surprisingly, I managed to write off my rear rim on a forest fire road, running Shwalbe X One 33mm tyres at 45 psi on the rear.
As a result, I now regard the wheels as a bit fragile so it has introduced a degree of wheel preservation anxiety that has detracted from any off roading that my previous wheels would have shrugged off.
I'm not a big unit at 10 and a half stone. With hindsight I wish I had prioritised durability over weight.
Has hunt offer to replace the wheel under warranty?
I got a set of Mavic Allroads to replace the stock wheelset on my Cube Nuroad. They roll well and seem to be holding up to the abuse I've given them (stuff I should really be using the MTB for). I got them through the C2W scheme though, so would have probably gone for Hunt 4 Seasons if it was my own money.
Hunt four season for me as well - had them 18 months - zero issues
I stupidly built a slightly pimp set of wheels for my gravel bike that I'm now afraid to use as CX training wheels during the winter.
Problem is, I'm running rim brakes but a 135mm frame.
Can you space Hunt 4 Seasons for 135mm QR? Anything else you could similar with that isn't a disc brake wheel?
I know I can do it with a DT350 but just hoped to buy something a bit cheaper...
Hunt 4 Season Gravel given the weight and riding you mention. I've had mine a year and they're still true, run smoothly and look brand new.
4S gravel here too. I'm 100kg and ride some bumpy terrain on South Downs plus potholed roads. 40mm rubber. Had them gotta be 3 years and they're straight and true. I've replaced the freehub in that time and that's as far as any maintenance goes.
Theres your problem, not your wheels.
Hi Guys
Thanks for all the responses.
I think I will pull the trigger on a set of hunt 4s 🙂
DT Swiss GR1600 are what I'm looking at, a little over budget. I think they can be had for about £370 ish at the moment from some of the european sites.
