Gore Shakedry - C5 ...
[Closed] Gore Shakedry - C5 or C7?
[#11077613]
Trying to get my head around the different versions, I think the one I like the most is the C5 with the fluoro panels, but I don't want a baggy fit.
Buuuuut is the C7 so slim fitting that you couldn't get a layer underneath?
Guess I should find somewhere to try them on. What to the other slim(ish) 6 footers wear?
Ta
Posted : 06/03/2020 12:53 pm
Mine is a C5 and while it's a looser fit than the C7 I certainly wouldn't call it a loose fit. I think it primarily comes down to whether you are going to use it as a race cape style jacket that spends most of it's life in your pocket for the odd summer shower or are you going to want to occasionally have a couple of layers on under it.?
I'm 6'4" but wouldn't call myself slim (my self image says more like retired rugby winger!). Main problem I usually have though is arm length and body length. The C5 has been perfect on both counts and is a good fit, and although it has a wee bit of extra room, it's nowhere near the kind of flappy 'boil in the bag' jacket you might be worrying about.
On a related note.. it's flippin' amazing, first rain i was out in with it on I nearly crashed into the guy infront a couple of times I was so enthralled by watching the water rolling of it.!! 😀
Posted : 06/03/2020 4:01 pm
Great feedback, thanks.
What size did you choose? Chest measurement says XL but arm measurement says L. Certainly wouldn't complain about longer arms.
I guess most of the time it would be used for steady rides, so a bit of flappiness wouldn't be an issue...
Posted : 06/03/2020 4:10 pm
I went XXL but I'm probably a bit bigger than you and have issues across the shoulders (I refer to my previous comments about rugby player self image delusion).
I would go with the chest measurement. As I said before the 'looser' fit of the C5 isn't anywhere near what I would call 'loose'.
Posted : 06/03/2020 4:18 pm
Good, had assumed you might be 1 suze bigger than me, and yes, it's usually across the chest that I feel any restriction if something is too tight.
Excellent, combined wifey/family birthday present request sorted 😎
Posted : 06/03/2020 4:23 pm
Just remember to keep your eyes on the road rather than being mesmerized by the wonder material.! 😛
Posted : 06/03/2020 4:34 pm
How about the C7 Shakedry Stretch?
Posted : 06/03/2020 5:31 pm
The stretch version seems to be consistently £75 more expensive, and even the discount prices I've seen on the C5 are my top end!
Posted : 06/03/2020 5:36 pm
To help with sizing I'm 6' 2", 38" chest and 11st 5lbs and the large C5 is perfect for me.
In winter I wear a merino base layer and a windstopper jacket and the C5 is a perfect fit over those 2 layers, in summer over a light jersey it's obviously a bit looser but definitely not baggy would happily wear all day.
I've 2 minor criticisms, the zip pull in the rear pocket/stuff pack is not 2 way and it can be a pain to use when it's inside out and being used as a stuff pack - it's fine for pocket use.
The sleeve cuffs can be a bit of a faff to pull over thick/winter gloves, the cuff is half elasticated but it's still a pain - solution (for me) would be a small zip with storm flap underneath at the wrist which would make it so much easier to seal at the glove join.
All in all a great jacket but not quite perfect, would I buy another - yes but only at a sale price (got my current one for £150 about a year ago)
Posted : 06/03/2020 8:46 pm
And I'm 42" inch chest with a C5 xl and it's "snug" but not too tight.
Posted : 06/03/2020 9:46 pm
I bought a few of these -C5 I think - the one with the yellow sleeve & back panels & had to send them back as the sizing is all over the place & not as indicated in the sizing chart. I would order a range of sizes & send the ones back that don’t fit best. Mine is a bit loose but I want to be able to layer up underneath it. They are good though.....
Posted : 07/03/2020 10:07 am
 tlr
I have the C7 - amazing fabric but at 70kg and 186cm I’d prefer more length in the body and slimmer cut in my Large. Maybe I should have bought the Castelli Idro that uses the same fabric.
Posted : 07/03/2020 10:18 am
