I recently got an HD, with a chesty mount. I've got the camera angle dialled now, but when I watch the vids, it seems quite jiggly. Has anyone else had this?
What to do?
You'll go blind
"but when I watch the vids, it seems quite jiggly. Has anyone else had this?"
Make sure its on fairly firmly and glue or silicone the camera bracket to the chest plate.
Increase the tightness of the chest mount, but it does reduce your lung capacity though!
+1 armo. I cant get a full lung full when filming!
I don't do mine up that tight, nor have I glued anything!
Do you have the right door on the plastic housing? Is the rubber bit that presses against the camera in place?
All I do is tighten the chesty so it's comfortable, but make sure the camera is secure inside the plastic housing and the threaded bracket bolt is done up tight - vids i've posted on here don't have any shaking
