GoPro mount compati...
[Closed] GoPro mount compatible Head Torch
[#8102196]
Are there any self-contained GoPro mount compatible head torches out there?
All I can find is the [url= http://www.magicshineuk.co.uk/bike-lights/mytinysun-folkslight-2000-lumens-integrated-battery-designed-and-built-in-germany.html ]MyTinySun Folkslight 2000 lumens bike light[/url]
At £130 and 2000 lumens, it's too expensive and too powerful for my needs. I'm looking for a supplement head torch as I already have a 2000 lumen light on the bars. Probably something that's around 800 lumens would be ideal.
I've got a Bell Super 2R and this has a GoPro mount. It has MIPS which makes adding a mount that straps on difficult, so making use of the Go Pro mount would be much better.
I've also got a mtbbatteries V2 which might be able to be adapted, although having a separate battery isn't my preference
Posted : 11/10/2016 1:50 pm
you can get replacement mounts that fit most separate lights for about £1.50 on gearbest/amazon/aliexpress.
Not as neat and tidy, but saves buying yet another light.
Posted : 11/10/2016 2:05 pm
I just put an adapter on my Solarstorm
Posted : 11/10/2016 2:15 pm
I could give an adaptor a go. What are they called? There are loads of options on Amazon when I look for GoPro mount!
Posted : 11/10/2016 2:22 pm
I just searched GoPro mount, look for these (the prices vary for the same adapter)
http://www.ebay.co.uk/itm/1-4-Adapter-For-Gopro-Mount-to-AEE-TCL-JVC-XIAOYI-SONY-Action-Camera-/121981321213?hash=item1c66a73ffd:g:tYIAAOSwubRXMFkK
Posted : 11/10/2016 3:00 pm
https://flic.kr/p/M9vgCG
This torch would have been to heavy to mount on the side of my bike helmet so I adapted it to fit on the go pro mount of my Goldeneyes helmet.
I happened to have;
A spare rubber mount from an on one jobsworth asterion
A lezyne macro duo torch
Expletives deleted
Various go pro bits and pieces
And somehow it works.
The strap from the asterion holds it rock solid.
Once it gets too dark to film with the sjcam, I can replace it with this for a safer ride home.
Posted : 11/10/2016 6:16 pm
Raceware do a few, I looked at their Exposure range for my Diablo when a helmet I was considering came with a GoPro mount www.racewaredirect.co/shop/exposure-gopro-mount-small/
Posted : 11/10/2016 6:24 pm
I use a Joystick in an adapter for the GoPro mount on my Urge Enduro as it's a sod to mount anything else on it.
Posted : 11/10/2016 7:48 pm
I have a joystick and ^that mount^ on my Bell Super.
No cables, plenty bright, good tight fit and doesn't budge apart from when clipping big branches
Posted : 11/10/2016 8:42 pm
I was able to just screw a GoPro adapter to my Chinese Cree light for use on my helmet.
[url= https://www.flickr.com/photos/144858550@N07/shares/FPG2g0 ]https://www.flickr.com/photos/144858550@N07/shares/FPG2g0[/url]
Posted : 11/10/2016 9:31 pm
placemark
Posted : 11/10/2016 9:36 pm
@greatbeardedone
Could you send me some details on what you've done there. Got exactly the same light that would be good to attach to the GoPro mount on my Bell Super, looks ideal..
Cheers!
Posted : 12/10/2016 7:15 am
So after trying to do this on the cheap and use what I had.....I ended up buying an Exposure Joystick!
Posted : 20/10/2016 10:26 am
@jonnym92
Just spotted your post
Will endeavour to post some pics over the weekend:)
Posted : 20/10/2016 1:50 pm
Just got a mount for my Lupine light, which allows me to mount it on my Super 2R Go-Pro mount. Works much better than the velcro original, which I found needed backed up with a couple of zip-ties to stop it wobbling around at speed.
(Dons tin foil hat) I was also considering that the MIPS liner would be compromised by having a couple of velcro straps tightened against it. I'm not sure how valid that is, but the whole point of having a MIPS liner is allow it to rotate freely, so potentially stopping that from happening seemed a good idea.
Posted : 20/10/2016 1:59 pm
GavinB what mount did you get
Posted : 20/10/2016 4:15 pm
I agree completely. Have you seen how much the MIPS liner actually moves? Any velcro straps over it will render it completely ineffective. I played about with the Exposure helmet mount earlier and even with that behind the MIPS liner it seemed make it less slippy. Plus the Bell 2r GoPro mount is breakaway
Also in response to an earlier post, Exposure do their own GoPro mount [url= http://www.exposurelights.com/cycle-lights/brackets-and-mounts/mount-for-action-camera-brackets ]http://www.exposurelights.com/cycle-lights/brackets-and-mounts/mount-for-action-camera-brackets[/url]. Sort of makes the Raceware one pointless unless I'm missing something? I'd always go with a manufacturer's own components over third party, just in case I have any warranty issues, e.g. the mount breaking and that in turn breaking the light
Posted : 21/10/2016 12:03 am
https://www.flickr.com/gp/98219308@N08/ULN7yQ
Well, I had a two prong GoPro mount with room for a 4mm? Allen bolt.
The Allen bolt secures the GoPro mount to the (spare) mount from the jobs worth asterion.
You will need to disassemble the asterion mount (afaik there's a small spring in there!) and place a washer and one of those nuts with the rubbery thread inserts inside the asterion mount.
If everything's the right size, there should be nothing protruding from the side, opposite to the Allen head.
At this stage you may wish to add a small patch of rubber (maybe from a tyre repair kit) to strap in order to keep the profile round.
Posted : 21/10/2016 12:15 am
https://www.flickr.com/gp/98219308@N08/52DXc8
As you can see, it's important that your Allen bolts are not so long as to poke through this part, as it's going to wrap round your torch.
Hope that made some kind of sense.
I tried to peel back the underside of the mount, but the camera struggled to focus on said washer and rubbery threaded nut.
Posted : 21/10/2016 12:23 am
Anyone know if those exsposure mounts will work with the ultra fire torches
Posted : 21/10/2016 6:50 pm
