Gopro fullface moun...
[Closed] Gopro fullface mounts
[#5926976]
Going to Inners this weekend and want to use the adhesive patches that came with the Gopro on my fullface. How secure are they
Posted : 06/02/2014 9:51 pm
Very secure just make sure you wipe the surface with an alcohol wipe before you stick in on
Posted : 06/02/2014 9:55 pm
Aye, very secure, I clattered the camera off a tree one time, no fuss. Curved plates generally work best btw and sidemount is IMO better than top.
Posted : 06/02/2014 9:58 pm
Going to go side mount,thanks guys
Posted : 06/02/2014 10:00 pm
Chesty is besty.
Posted : 06/02/2014 10:03 pm
The surface mount on my snowboard helmet had held-on despite countless face-plants.
Posted : 06/02/2014 11:21 pm
For side mount on a full face use the helmet mount for a normal trail helmet.
Pass the nylon straps around the chin piece, they will overlap, andthread them through the clamp.
Rock solid mount and a great view.
[url=
plug of me riding, feel free to mock :)[/url] and if you watch allthe way/ skip to 5m 10s you see how sturdy the mount is....
Posted : 06/02/2014 11:34 pm
Won't let me play the video on youtube saying it's blocked in my country on copyright grounds
Posted : 07/02/2014 12:00 am
as above, use the curved mount on the side of a full face. Give the area a clean then alcohol wipe and it will be very secure. I've had a couple of big offs and the mount, complete with gopro, hasnt come loose at all.
Posted : 07/02/2014 9:44 am
An alternative I use which works very well and adds protection for the camera is:
[list][*]Get the elasticated head mount[/*]
[*]Remove elastic (there are splits in plastic to let you do it non-destructively)[/*]
[*]Drill a hole in it.[/*]
[*]Mount by using the adjuster bolt in the middle of your helmet peak to secure the mount under the peak (might not work on all helmets but works a treat on Giro Remedy).[/*][/list]
Here's my mate with one mounted this way:
[img] http://www.mountainbikerides.co.uk/photos/image.raw?type=orig&id=4439 [/img]
Posted : 07/02/2014 10:27 am
