Goodridge Yellow Ta...
[Closed] Goodridge Yellow Tags.
[#3959365]
How do you fit them?
I thought they were heatshrink.
A couple of minutes with the Mrs's hairdryer says they're not though. 😕
Posted : 09/05/2012 9:06 pm
Never crossed my mind that they might be. I just pushed mine so they slid over the shroud nut on the connectors.
Posted : 09/05/2012 9:08 pm
you brand whore! Just leave them off 🙂
Posted : 09/05/2012 9:13 pm
I set fire to mine thinking they were heat shrink. They're not. Bit of glue will hold them, I was a bit disappointed to be honest, Heatshrink seemed like a good idea.
Posted : 09/05/2012 9:17 pm
As per Onzedogs suggestion.
Actually, as per Stoner.
got a load in the shed. Really should eBay them.
Tim
Posted : 09/05/2012 9:18 pm
have you tried holding them between your lovely thighs Stu? they are HOT and will sort it out far better than a hair dryer. Failing that, i can send you something sticky in the post 😉
Posted : 09/05/2012 9:22 pm
something sticky
Posted : 09/05/2012 9:23 pm
That looks more twiggy than sticky. 😕
Posted : 09/05/2012 9:25 pm
no, that's twiggy
Posted : 09/05/2012 9:26 pm
Does she know how to fix the tags on?
Posted : 09/05/2012 9:31 pm
yeh, apparently you have to use something sticky 😀
Posted : 09/05/2012 9:32 pm
Very helpful Tazz.
Posted : 09/05/2012 9:51 pm
Either push them over the connectors or wrap a bit of insulation tape round the hose & fit it over that.
Do you need reminding that you have goodridge hoses fitted just incase you forget?
Posted : 09/05/2012 9:53 pm
First one I fitted I held a lighter to it and it melted. Second one, I used a bit of electrical tape on the hose/connector and pushed the tag over it. I use the second option every time now.
Posted : 09/05/2012 9:55 pm
No Rich.
The fact that the hose isn't pissing oil from the fitting onto my pads and stopping the brake working should remind me that it's not a shimano hose. 😉
Posted : 09/05/2012 10:00 pm
do they fit SP41
I want to be rad 😥
Posted : 09/05/2012 10:01 pm
