On my fox 36 Talas there is a gold screw head on the bottom of one of the legs.
Does anyone know what it is? They are only R's so dont have all the compression adjustment. It seems to be in a 10-12mm nut?
Also, does anyone know how easy it would be to get a little more rebound in my RP23? I seem to be on the max with it not quite slow enough!
send the shock back if I were you
Mind best you pay for the bike to 😉
Andy.... your useless!
you forgot to say "fugging"
well come on if there is not enough rebound damping there is a issue with the shock it is not as if you are a light weight. So I would say there is a case to send it back
Yeah... its set a medium on the sleeve, but i think im runing it a few PSI high at the same time! Will play on thursday when im riding all day.
Was wondering if anyone else had the same, twas all!
